A/T Secondary Pump
I would check for a stuck Kick down switch under the gas pedal, you should be able to push it by Hand, if you don’t hear a Click, it’s stuck ON = no up shift.
Also check the Bowden, throttle valve cable in the engine compartment, it must have some movement, not seized or stuck.
If the Bowden cable and kick down switch check out ok drive the car with the Bowden cable disconnected, if the car shifts, the cause is valve body related. Post pictures of the modulator pin, can you check for an up shift delay actuator, located on the passenger side front of the transmission.
This transmission obviously was out before and looking at the valve body it looks like there is a ball/check value missing in position 14a as per the ATSG manual....pressure valve.
Brian
1993 400E, chassis 124.034 Engine 124.034, Trans 722.354
A 722.366 transmission should fit work in your car. Make sure you install the protection switch, and make sure its working, no codes, if not the ECU will default to a retarded timing setting, if it doesn’t see the switch
Accumulator K1 controls 2-3 shift feel. Shift Valve B1 and control valve B1 controls a 2 -3 shift, install the original springs and clean the 3- 4 and 2 -3 command valves. Which VB kit did you use.
Did you flush the converter and transmission fluid cooler in the radiator, you could have contaminated the valve body with Debris or Bowden cable out of ajustment.
I put the original springs back in. The valve body looks clean but I didn't flush the converter.
This kit had some pretty strong springs in the K1 and B1 accumulator. I was supprised when I removed them.
I also notice that the Bowden cable does need to be adjusted.....those 2 pointed plastic bits need to match...right?
Also, part of this kit requires you to increase 3 holes in the seperator plate..which I did. One to give a firmer K1 (2 -3) shift, another for a firmer K2 (3-4) and the other one to reduce the delay engagement to drive, B2 ???.
Went up to .062
Anyway, now that I removed all the springs I hope these larger holes don't create a problem. The plate I drilled was from the 722.366 transmission. I still have the one from the 722.354 and it ias almost identical...just 2 extra holes.
Doesn't seem like much......should I put it in or stick with the one that came with the replacement transmission (.366)...even though I drilled it.
Lottsa fun....
The 3-4 shift is also "unwilling". It will shift but not until the RPM gets up there. Downshift is now positive and instant, quite aggressive. That is city driving. On the hwy as I enter if I put my foot into it she goes up through all the gears, no problem. Just seems to be when I drive it normally it acts up. The 2-3 and 3-4 city shift should be smoother. Right now it hesitates to go into 4, but I can get it there if I play with the throttle and manifold pressure, I suppose....which made me think modulator valve. So, I am going to re-spring the valve body and see if we can fix the city shifting attributes. Any other ideas Steve?
I would look at; throttle valve and plunger, governor pressure valve also called, governor idle control valve, a sticking governor valve.
Adjust the Bowden cable when the pan is removed; adjust until the cable lever just contacts the throttle plunger, then fine tune on a road test. If you have a stretched cable the adjustment marks would be wrong.
Use the original springs and plate, so you can eliminate the valve body as the cause. A leaking K1 or K2 drum or sealing rings can also cause late 3rd to 4th shifts. Internal, did you have trouble installing the drums.
I know Mario well; he had a shop in South Miami.
