parktronic issues
2003 clk55 amg
parktronic issues
Hi everyone, my sensors on the front left side are driving me mad. every time I come to a halt they go off full beep with nothing anywhere near them. Have not got time to take it to MB at moment and on the basis that I rarely have need for the front parktronic i want to disable the beeper. Can someone tell me where the beeper is located and secondly where is the control unit for the front sensors.(might check for something loose etc...).
W211 / E280
2003 clk55 amg
Thanks Jakarta, did you manage to fix this yourself and if yes how did you get at the clips. plus:
Do you know where the control box is located?
Do you know where the beeper is located for the front display?
just pull the fuse rather than having to use the switch everytine you get in thecar if you open the drivers door youll see a little panel on the side of the dash, pull this off with a screwdriver underneath it, it should just pop off and the fuse list should be in there. i think the beeper is part of the cluster! not sure though. youll need a plastic wedge/protected screwdiver to remove the front trims around your sensors
2015 E250D
2003 clk55 amg
Hightower, the dealer has already replaced one of the sensors in the same area where the current problem is.They told me they have to remove the entire front bumper to replace them, can I get to them by removing the trim around the sensors? and does each one have a connector at the back or do they have a wire coming out which goes back to a plug and socket for all the front sensors?
it depends, if you look at the trims in the bumper around the sensors you will be able to pull it slightly by poking a screwdriver into it, if you can then they should only really have to pull the trim off, it is easier with the bumper off though, there is a wiring loom that comes from the front SAM (fuse box) this has 6 plugs on it running along the front bumper, one of each attaches to a sensor. are you able to get a printout from the star test they did when u had the car in?
2003 clk55 amg
OK that sounds like it might be difficult. The beeping sounds as if it is coming from inside the display pod on top of the dash, can anyone tell me how to get inside this thing as it seems to be fairly tightly fixed.
