New Brake Job, now a warped feeling when braking?
Here is are two EXCELLENT articles from StopTech and Zeckhausen Racing on bedding in brakes. More importantly, it explains what causes that 'warped' feeling, even though the rotors themselves are not warped;;
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
http://www.zeckhausen.com/bedding_in_brakes.htm
It takes awhile to read but I think it will answer your question well.
I guess I have a couple of things to check on. I do have a bulge/bubble in one of my front tires so that may be causing part of the problem.
Could it be due to over tighting or not a consistent fit on the lugs on the rims as well?
Since these are OEM brakes and not reall high performance stuff I didn't think there was any real proper brake in procedure. I'm guessing I can still do this and hopefully burn off any material imprints?
QUOTE]
If you have a bubble/bulge I would change the tire immediately. It could blow out and cause serious damage to the car and you in an accident.
Also if the lugs were not tightened properly you could have warp in a rotor. Final comment the mounting flange where the rotor mounts should have been cleaned at installation to insure running true also. Jim
