'03 E500 Sport - "Whirring" Sound
Hard to describe the sound. Not a grinding sound. More of a "whir". It happens only when the car is cold AND I make a 3/4-to-full lock turn (e.g. I'm backing out of the driveway, turning onto the street.
Once the car's warmed up, and I make those turns, there's no sound.
Any thoughts?
Any thoughts?
03 E500 and Corvette
It could be normal if your system is not low on fluid. Ours has been making a "simular" sound since new but only cold. I think it is the clearance on rotary vanes in the power steering pump. Ours is not an abnormal sound, after start up/warmup it goes away. Jim
Yes, it's weird in that the sound goes away after the car warms up. Did you ever take your car in to check out? I've noticed the sound for months now, and have just been lazy to bring the car in. But I've noticed the sound starting to get louder, so I'm starting to wonder what the cause is.
If the sound is getting louder, the pump could be in a failure mode. There are vanes in this pump that have very close tolerance to maintain the pressure and angles needed for operation. If the slots for the vanes are wearing open the noise will begin to change. Doesn't mean instantenous failure but failure in the near future. I would recommend having it checked if the sound is changing. Expect to pay big $$ for the power steering pump. Jim
I would expect a powersteering pump to be covered under the warranty. This is why you should have it looked at. Since the noise is getting worse it might be worth the effort. Jim
Update
I finally got around to visiting my dealer. They topped off the power-steering fluid. The sound is gone...it's been a week so far. Thanks for your help guys
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Glad to hear that's all it was. We have different cars, but when I had a pre-winter check-up last fall, the tech had to add some power steering fluid to mine. I was charged for 1 bottle, but I don't know how much he actually added. I don't remember ever hearing a noise like you described, so maybe it was not low enough for that to happen.
vettdvr
I don't know, but they never told me I had a leak. I might not have even noticed that they added PS fluid except for the service writer pointing it out. He didn't say this, but made a sound and gave me a look like that was indicative of a problem. If the level is low, it has to be going somewhere doesn't it? If it's a completely sealed system, which I believe it is, I don't think it can evaporate or dissipate into thin air!
