Crank Position Sensor on a 99 ML320
Thanks for the help.
with misfire on 4,5 and 6 cylinder, code P0410 and ETS light on,
I been told is my Cat but wanted to know if you someone here have fixed their misfires with the replacement of the CPS Sensor?
thanks for the advise
all help is welcome
As far as the mifire being a cause of a faulty CPS, that wouldnt be the case. If you want to see if the cats are out, rev the engine on park slowly and if you hear a binging noise or rattling coming from the middle part of the car, then cats are out. sometimes you can hear it but sometimes you wont. depends on how severe the damage is. If the cats break apart, you might lose all power and just feel like a struggle to drive the car. sometimes only one goes out at a time. also, your local auto store rents out OBD2 sensor reader and that should tell you as well. Cats are pretty expensive so try to diagnose from the smallest parts. check wires, plugs etc. Good luck!
