O2 sensors covered in emissions warrantee
Old Sep 27, 2007 | 02:48 PM
platt-deutsch's Avatar
2019 S450
Just had 2 o2 sensors replaced and dealer says not covered under emmissions warrantee. My owners manual says they are part of the emission system so I think they should be under the 80K 8yr fed. emissions warrantee does anyone have any reference that I can use to back it up?
Old Sep 27, 2007 | 03:44 PM
lkchris's Avatar
'10 CL550, '12 GL550
In addition to your owners manual, you have/had a warranty booklet.
The 80K warranty only covers major systems like computers and cat converters.
Old Sep 27, 2007 | 06:35 PM
2019 S450
I didnt get a warrantee book as it was used car. That is not the answer I wanted to hear..as the O2 sensors are to monitor the condition of the Cats I hoped they were also covered..
Old Sep 27, 2007 | 07:34 PM
whoover's Avatar
'19 E63S sedan
Any item that is specified as a maintenance item, intended to be replaced before 80,000 miles, is exempted from the 80,000 federal emission systems warranty extension law.
A stricter law, in effect in CA, MA, and VT, covers the O2 sensor for 3 years or 50,000 miles. As a maintenance component, federal law only covers the O2 sensor for 2 years or 24,000 miles.
Old Sep 27, 2007 | 08:41 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
O2 sensors are consumables and should be replaced when they fail or trigger a check engine light. This is usually well before 80,000 miles. Cats are also consumables but normally last well beyond the 80000 mile mark. Cat failure is in many cases caused by the owner/operator using improper fuel or by not changing the O2 sensors when failed causing a very rich mixture and raw gas in the exhaust.
Old Sep 28, 2007 | 04:17 PM
lkchris's Avatar
MB states its Cats are designed to last the life of the car.
Old Sep 28, 2007 | 04:44 PM
sosh's Avatar
I have never heard that however the design attemp could be that. As I stated in a previous post most Cat failures other than mechanical/weld failures are caused by improper operation/fuel.
Old Sep 29, 2007 | 11:51 AM
2019 S450
If I read this right on this link the Fed. Epa warantee should cover the o2 sensors under the 80,000 8yrs warrantee.
http://www.epa.gov/otaq/consumer/warr95fs.txt
