PS fluid (Special?)
Old Sep 28, 2007 | 05:34 PM
platt-deutsch's Avatar
2019 S450
PS fluid (Special?)
I know the Hyd. fluid for the suspension system is special but what about the PS Fluid. Can I just use any or is is odd too?
Old Sep 28, 2007 | 06:05 PM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
Hydraulic oil
On my 2003 CL500 the power steering oil and the Active Body Control Oil are the same:
part no.Q-1-32-0001
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
File Type: pdf
Old Oct 3, 2007 | 10:30 PM
CFLPEEK's Avatar
96 c36
mercedes is now saying that any car with a 112 or 113 engine, or any engine after that, that you are supposed to you pentosin in the p/s except for 170' and 163's. if you have any of those cars, use regular mb p/s fluid.
Old Oct 4, 2007 | 04:21 AM
kjb55's Avatar
Do you have the MB bulletin that states this?
Old Oct 4, 2007 | 06:42 AM
Eurosport's Avatar
monowiper
search is your friend ;p
My MY02 service products manual states that you can use either the
MB power steering fluid (PN 000-989-88-03) or an approved Dextron III ATF. The list of approved Dextron III ATF is as follows:
  • Castrol Dextron-III/Mercon ATF F-30341
  • Castrol Transmax M-22257/22096
  • Chevron ATF Dextron III F-30108/30159
  • Citgo Multi-Purpose ATF D-21571
  • Exxon Superflo ATF Dextron III F-30111
  • Havoline ATF Mrcon/Dextron-III F-30321
  • Texaco ATF Mercon/Dextron-III F-30321
  • Penzoil ATF D-22413/F-30110
  • Quaker State Dextron-III/Mercon F30161
  • Sunoco ATF Dextron/Mercon F-30176
  • Unocal Multi-Purpose ATF D-22413/22431
  • Valvoline ATF Type D
any Dextron III ATF will do...
Old Oct 4, 2007 | 07:45 AM
CFLPEEK's Avatar
96 c36
yes, there is a bulletin stating this.
kjb55's Avatar
[/LIST]any Dextron III ATF will do...
If a search returns this information, I would post a new thread too. What good is this information? There are no model details, 2002? Obviously, MB has updated some things over the last 5 years.
The MB bulletin of 2006 states quite clearly that not just any Dextron III ATF will do.
Old Oct 4, 2007 | 11:38 AM
reddog's Avatar
July 21, 2006
Order No.: P-B-46.00/44
Group: 46
Subject: 171,203,209,211,215,219,220,221, and 230 Power Steering Fluid-Pentosin CHF 11S
"All of the above mentioned model vehicles must use power steering fluid Pentosin CHF 11S (MB part no. BQ 1320001.
Note: Model 210 which is equiped with rack-and-pinion steering gear and older models equipped with re-circulating ball steering box (e.g., 124,129,140,170,202,and 208) must use MB power steering fluid part no. BQ 1460001 or approved Dexron III ATF."
Old Oct 4, 2007 | 12:49 PM
kjb55's Avatar
Originally Posted by reddog
July 21, 2006
Group: 46
Thanks, see post #3.
Old Oct 4, 2007 | 12:50 PM
kjb55's Avatar
Could you post it? I'm wondering if it is an update to that posted in #3.
Old Oct 4, 2007 | 02:20 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
I didn't see the 126's mentioned.
I always use MB fluids, even when I don't care to pay for them, Am I also waisting dollars?
Bruce
Old Oct 4, 2007 | 03:45 PM
kjb55's Avatar
Bruce
I think the 126 would be in the group needing BQ 14600001, as it is a re-circulating ball steering box, but I'm not sure. I don't think it's a waste of dollars, it can be bit more, but the alternative expense is much greater.
Old Oct 4, 2007 | 05:37 PM
CFLPEEK's Avatar
96 c36
the 126's do use regular mb p/s fluid.
Old Oct 6, 2007 | 04:38 PM
RogueMBtech's Avatar
truck
As a few people stated the Pwr st fluid and ABC fluid is the same for your car it works off the same pump,its a tandem pump for ABC/Pwr st. you have to use Pentosin
Old Jun 10, 2017 | 12:53 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
It is a very very bad idea to mix Pentosin (MB ATF fluid) with Dexron ATF.
These two are incompatible and will kill the PS pump.
Now, while Daimler-Chrysler were together they developed ATF+4, which I believe was used as PSF on both brands....so it's important to check by the chassis.
The older Euro cars, pre 1996, used Dexron III. Dex 6 or ATF+4 is the newer replacement....some might want Mobil 1 ATF but not much to be gained over the other 2 synth spec OEM ATFs.
Let me know if anyone has more specifics on year and model range.
Old Jun 10, 2017 | 12:59 AM
Dex III has been superseded by Dex 6. Technically, the spec doesn't exist...it's not licenced, but any Dex III is the same as any Dex III, I assure you with the exception of an old bottle of Mobil 1 ATF that still says Dexron III.
