transmission fluid
...Tough it is not prescribed maybe you can change the fluid and the filter every 100000 kms (= ? miles), but in that case I would also recommend to reset all adaption values with the Star Diagnosis laptop.
With the Star Diagnosis laptop there is also a possibility to check the state of the fluid.
A mechanic who is familiar with the system can tell, depending on these values (state, adaptation,...), if the fluid needs to be replaced.
Patrick
https://mbworld.org/forums/showthrea...k&pagenumber=3
But remember, the fluid of all electronic MB transmissions should not be changed. This because the transmission ECU "adapts" to changes in wear, fluid and so on.
I certainly would not change the fluid without doing the adaptation procedure!!!!!!!!
Patrick
Expire at ..Just out of warranty! And Mercedes says Gee Im Sorry your car is OUT of Warranty! And The Crap in the trans Pan Is Scarey!This is a Marketing ploy..Lifetime fluid. same as the FSS System ! (Oil Changes at 15k) Have you heard of the lawsuit on Late MBs With The FSS? Do a search on it!
Well The Lawyer Won ! and Now the Engine has a 150k warranty on oil consuption!also I Think he (The Same Law Firm) Is Working on the Lifetime trans Issue
Yes The trans has a Tamper proof lock on the Dipstick and Yes you will need the MB Dipstick tool to check the fluid level.
Also Make sure you drain the torque converter!
The Quote (LIFETIME) is a Joke! The Fluid Should Be Changed at 30/60/90k I Have Seen SEVERAL late Electronic Transmissions
What do you mean with "the crap in the trans pan is scarey"?
I will wait for a technical explanation of these things that I consider until now as "newspaper talk".
I admit that "lifetime" is not really "lifetime", but maybe a few 100k for the transmission fluid.
Mercedes gives "lifetime warranty" on rust, but according to certain laws it is in fact 30 years. That means to say that for legal purposes a car's "lifetime" is considered as maximum 30 years.
I am also quite sure that if you follow all MB prescriptions concerning the FSS, you will not have any oil consumption.
Can you also tell me which oil is used and at which mileage the oil have been changed from those cars that consume oil? Can you also tell me what you consider as "oil consumption"?
Many people also do not know how to check the fluid level (btw, how do you know exact transmission oil temp), so MB protects these people against themselves by sealing the dipstick tube.
And if you do not have any leaks, why should you check the fluid level?
I sure know that there is a lot of misunderstanding about the way the MB electronic transmissions work and should be serviced, even at MB workshops.
I have already made some things clear at this forum:
Since they made those transmissions from 1995 on, we have seen many of them last as long as the whole car itself.
My opinion is that every time a new model comes up it takes some time to attune the software to the needs of the model. For this reason there were some problems in the beginning (control units and valve bodies needed to be replaced) and now we have these problems again with the 211 model (control units are modified and some of them need to be replaced).
The problem with the valve body is that it only can be replaced as a whole unit. It definitly is not that complicated as the "brains" were on former types of transmissions. But if, for example, one of the electric valves on it does not work right the whole body needs to be replaced.
In the beginning we have been fully informed by Mercedes about "known" problems with mechanical parts, but we have not seen many of them in the workshop.
Now, if we have one in the workshop with problems with mechanical parts of the transmission, it is mostly because they neglected to visit a (good) workshop after having oil leakage.
(For example they "feel" the transmission does not shift as usual and sometimes they have seen something on the floor of their garage, but just keep on driving)
I am pretty sure that the mechanical part is quite good, but it is just a pity that the valvebody only can be replaced completely.
Tough it is not prescribed maybe you can change the fluid and the filter every 100000 kms (= ? miles), but in that case I would also recommend to reset all adaption values with the Star Diagnosis laptop and do the adaptation procedure again.
(In fact I would certainly not change the fluid without doing this!)
Patrick
No amount of transmission fluid replacement will stop premature wear if you drive with your foot on the floor all the time. If you are concerned about wear then take it easy on the upshifts and reduce the kickdowns.
Patrick,
Is it too much to change my ATF on my 94 c280 every 10k miles? Too ****? What does MB recomend 30k intervals right?
Patrick
...The law suit you mentioned is FSS related and Mb is guilty for that. However, since full synthetics started fulltime, there has been no FSS related failure that I have heard of...
Thanks,
Patrick
I also wonder how long he did without changing the oil, because I am pretty sure that there are plenty of oils that can be used while following the FSS without having any problems.
For as long as it is a type of oil that is on the MB 229.1 oil prescription list.
That list also mentions non-synthetic oils. This is susceptive to many discussions because some oil manufacturers claim certain production processes (e.g. "hydro-crack") to be a sort of synthetic, while others do not.
But if one drives a Mercedes why look for cheaper oils?
[B]Who are you that you know the fluid should be changed "every 30/60/90k...?
Who Am I? I Have Over 20 Years of Dealer Experience
on Mercedes and Porsche ..I have seen Several Late Trans
Expire at just past the Factory Warranty..With no help from Mercedes....Yes the Dealer sees this Problem With Late transmissions And yes the Problem is Still there ..As I Have Several friends Still With mercedes That I Stay In contact with!
If You Choose to do the Service By The book, Go Ahead!
I want My car to last Past the warranty!
BTW I Also change my oil @ 3,500 miles with Mobil One !
Better to be safe than Sorry Just My .02
I didn't take the time to skim throught the responses to Mr. Cummins misinformed opinions yet, but I hope someone has chastised you Mark. These trannies last a very long time and the FSS works. I have no idea where you get your wrong information from. Even in my 89 Nissan A/T, the tranny fluid change is at 60K. The law suit you mentioned is FSS related and Mb is guilty for that. However, since full synthetics started fulltime, there has been no FSS related failure that I have heard of. I changed my oil according to the FSS at 13060 miles (first A service). I had the oil analyzed just to see if it could still protect. There was still enough protection in the oil to carry me several hundred miles, maybe even another 500 miles. The FSS works, period. The tranny fluid had some carborn self lubricating compound in it -that's why it's black. It will likely outlast the car itself, in most normal driving conditions. The general take (including BMW's) is to perform the sevice at 100K - same time as the spark plugs. Man, get your information correct b4 misleading others!!! If you feel like doing the services before FSS requests, that's fine but it's not necessary.
friends at Several MB dealers that I stay in contact with and the Trans are STILL Having problems!
This Is My Opinion and I was Just letting Others Know What I have Seen (First Hand) from working on them (The Late Transmissions)
Misinformed Opinion I Dont think so!
I also have my engine oil sent out for Inspection Report.To the Lab that Inspects the oil on my Airplane (every 25 hours)With no problems..as of Yet.Just want to be Safe!
After what I have seen I Will Recommed Transmission Fluid Changes !That Is My Opinion!
As a result of my experience, I will be sure to change the ATF and rear diff fluids in the clk on a more reasonable timeline. Listen to what you will, but I know I will do anything within my power to avoid any more $5K transmission jobs.
...My independent mechanic has also seen numerous examples of dead transmissions due to the "permanent fill ATF...
But can he explain why those transmissions "died" because of the "lifetime" ATF?
"Dead" = ???? What was wrong, broken, etc... and what has it to do with the fluid?
Please answer me, I am curious!
(concrete technical details please)
Patrick
I am not a forensic MB mechanic, nor do I have the expertise to give you the "concrete technical detail" that you so desire.
I did not post to engage in some internet fight, just to add my experience and assessment of the content of this thread.
Here are the facts as best as I can present them with regards to my dead transmission:
@ 105K miles...driving around at city speeds <50 mph I notice that upon upshifting from 2-3, on occasion, the gear does not engage and revs climb. In reaction, I back off the throttle, and as the gear catches, the car jerks violently. This begins sporadically, but the frequency increases over a two week time frame.
I take the car to the dealership for diagnosis then to my indy to be fixed. I'm sure he'd be happy to furnish you with the technical details and explain his recommendation to change the ATF at 60K mile intervals.
Zim Gwee
Topline Automobile
(650)558-8999
Thanks!
...My Information comes First hand I was a MB factory Tech!(Retired)...
Patrick
The OTHER post Stated That I WasFactory Trained By Mercedes at a Training center (Factory) Here In the USA. Maybe YOU Misunderstood that? But That is My Definition of it.
( By MERCEDES from a MERCEDES center MBUSA ) OK?
Paomien, I Would Find a Good Indy.To do the Trans Service if you Want to have that done !Please make sure that the Indy has The Factory....oooops I Mean the Correct Dipstick Tool to measure the fluid after its changed!
Or You can do the Maintence by the Book(LIFETIME)
First you were an "MB factory tech" (see quote), then you just went to an MB training center (once?),...seems that you are diminishing!
If everyone is better off without Mercedes, why did you go to that training? To know more than independants do?
If independants are that good, why do they bring so many cars to the dealer to fix?
Do you want to know how many phonecalls I get a day by independants who got stuck with MB's because of not knowing what they are doing?
If you are really that experienced you should know that there is no one that knows your MB better than the dealer.
Patrick
Mark,
Patrick
Yes I Posted That I WAS a MB Dealer tech Trained by the Factory That Supports all MB Dealers! I THINK THAT IS CLEAR BY NOW..ok? GREAT MOVE ON!
NO I Dont care how You spend your day on the Phone
Because Its Not the Point of Interest Here!I Was Trying to Help People RE The Transmissions That Puke after warranty and MB wont help them ..ALL I Stated It was MY Opinion From What I Have Seen Working At the Dealer (MB)OK?The ONLY Thing That Is Diminishing Is This Thread From Your Off Subject Matter!
Patrick HI!
Yes I Posted That I WAS a MB Dealer tech Trained by the Factory That Supports all MB Dealers! I THINK THAT IS CLEAR BY NOW..ok? GREAT MOVE ON!!!!!!!!!!!!!!!!!!!!!!
I Posted That The Person/persons Should Go to a Independent MB shop Because of FOOLS Like YOU that THINK the TRANS fluid is LIFETIME ! NO I Dont care how You spend your day on the Phone
