Request for Stealth Bulb Feedback
Has anyone had any experience with the "stealth" bulbs - the kind that are made for use with a clear lens? For example, I've looked at the chromium type sold by Hoen and the silver bulbs made by StealthAuto. Of course each company says their bulbs are the best. Who am I to believe?
Also, in the photo of your rear lamp assembly it looks like I see a blue bulb in the lower white portion (not sure of the correct terminology for that slot) of the assembly. Is that what I can expect to see if I use Sylvania SilverStar bulbs in all of my clear lenses?
My front assemblies have the Stealth Auto bulbs. They have more of an amber tint. I've got over 80K miles on those without failure.
These are the front lamps.
Based on the photos that I have seen of your vehicle, I would probably go with the Sylvania SilverStar bulbs over the StealthAuto. I would rather have a bit of a blue look rather than that of an egg yolk.
How about the chromium type bulbs sold by Hoen? They claim to achieve 98% of the brightness of an ordinary amber bulb. Does anyone here have any experience with them?
Here is the after image.
Here is the side by each of the factory and the Stealth bulb.
I just installed the HOEN Chromium Bulbs (turn signals), H11 Endurance Bulbs (fog lights), H7 Xenonmatch (Hi-beams), and W5W City Lights (daytime running lamps).
After a bit of research I learned that yellow fog lights have a slight advantage over white fog lights. Considering that I only use them in foggy conditions, I decided to go with the yellow Endurance bulbs.
Here is the before pic...
Here is the after pic with the HOEN bulbs...
Also post 47 in the same string. The upper pic shows the lights on - you can see the yellow. They are off in the lower pic - lenses show no color behind.
Most of the bulbs with silver coating will show white in the side markers. Some illuminate more evenly than others.
Thanks, Skylaw. I just compared my side markers with the images in post 44 of the thread you referenced. I found that when my markers are turned on in partial daylight, they look similar to your pic #3 (1928.jpg) - the back part of the lens is lighter than the front.
I really like the way the Polarg G51 Visual Amber bulbs completely illuminate your side markers. I wish I had seen your thread before I ordered my Hoen side marker bulbs.
By the way...where did you purchase your bulbs?
