Mobil 1 Engine Oil
The different viscosities are indeed miscable but by adding a low-vis one to a high vis one does not necessarily result in a medium vis oil. Modern oils have some pretty funky chemistry. In a pinch, do it and don't worry.
MB recommends Mobil 1 10W-40 oil for year round use in North Carolina, I can't find Mobile 1 10W-40 anywhere. Is it ok to mix Mobil 1 5W 30 with 15W- 50 to equal 10W-40
NP
-s-
http://theoildrop.server101.com/ubb/...=005119#000000
If you guys have a stand-up persopn who wants to discuss MB oiling requirements in-depth, that would be cool. Otherwise I apologise for the lecturing tone.
15w-40 dino, great in warm climates
5w-40 synth, up to the job
5w-30 SM/GF-4 dino (HC) a cheap alternative that will work fine
0w-40 Mobil 1, prefered choice of dealers and CAFE MPG
0w-30 Syntec (German) da bomb
5w-30 Mobil 1, do not use it is too thin for German cars.
I am not having an issue about what oil you are hyping (I don't care for Mobil myself), but you've already made your point in several relevant threads (which is fine) but why do you have to dredge up old posts that haven't been alive for literally years and bring them back? Anyone searching for this information will get the newer posts first, so you can rest assured that your hype will be well represented even in search results.
I can disagree with the rest of your points, but that's not what I was doing. Heaven forbid I disagree with you and you think I don't like you!
-s-
I've been using Amsoil for years after having lost an engine to Mobil 1. I truly believe that with Amsoil you will never have an engine "metal" problem.
Check them out at amsoil.com
PS, that whnet list is very out-dated and most oils there are n/a in USA. Many oils are missing too. If you use the M1 0w-40 you will have nearly the best oil in the World.
