Why replace scored rotors ???
It seems to me, that new rotors should have grooves in them anyway, for more surface area. What is the real story ??? Unless there's a performance problem, why replace them ???
The other things would affect performance, which I would notice...
I've done other experiments on my cars, like NEVER changing the oil, just adding when low, and changing the filter once every couple years... never had a problem...
The cars you see burning oil have most likely run OUT of oil, and ruined the rings. They're lucky the car runs at all...
I had a 2 cylinder Volvo deisel in my sailboat. We ran it out of oil, and another time ran it out of water, and every time, after a cooldown, and fixing the problem, it started up, and ran (like a deisel).
It's all a matter of degree; like how much lead did you eat off the wall, or drink from your soldered plumbing system when you were a kid ??? Probably a billion times as much as they allow today...
To ease your mind, the vehicles I buy, I usually drive until they won't go anymore, so they go to the junkyard (usually after a couple hundred thousand miles) the best were 1974 & 5 RX7's, which burn oil in their cumbustion process, so I was cheating a little. Also, they have fewer soft metals and moving parts...
Of course, my wife's MB gets premium treatment. I'm an aerospace engineer, and some of us tried various self designed tests over several years... we even found a marine engine "zinc" that would screw into the RX7 cooling system, and it seemed to extend the radiator life...
If you reuse them you MIGHT,, have squeel until they fully bed the pads. I would say if you are within the criteria and want to try it give it a shot then report back. But otherwise I would buy new rotors.
Don't consider myself an expert,, but have had to make many things work and I have made grooved rotors work. Best of luck.
sosh - I've never heard of rotors cracking. Besides, I would guess they'd crack radially (greater stress) rather than circumferentially.
I've studied crack propagation, and you are right, the crack very often is deeper than you might think...
So for groves follow the specs. If your depth of grove is within spec as I previously said.. it might work. The depth of the grove is the real issue.
I assume you know that most commercial aircraft use retreaded tires...
