How to replace oxygen sensor?
Old Dec 30, 2002 | 12:36 PM
vwalk's Avatar
I have a 96 C-280. I had the car "diagnosed" after the check engine light came on. The mechanic advised that I needed an O2 sensor. Is the replacement a labor intensive task? If not, what are the basic steps to replace the sensor? Finally, how many sensors does my vehicle have?
Old Jan 4, 2003 | 03:00 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
The O2 sensor is located under the car, threaded in a hole on the exhaust pipe with the sensor wires running through a hole in the floorboard. It is a DIY job if you feel so inclined. There should be a thread somewhere about using the sensor from a Mustang 5.0 sensor (made by Bosch) that will work perfectly with a little surgery on the wire harness. You could also check www.oxygensenors.com. They sell the whole kit (instructions, wire crimps, heat shrink tubing) and USPS shipping for $40.
Old Jan 4, 2003 | 03:17 PM
vwalk's Avatar
Thanks for your respone. I'll give it a try.
Old Jan 8, 2003 | 02:00 AM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
Did your mech test the O2 sensor ?
NP
Old Jan 8, 2003 | 10:01 AM
vwalk's Avatar
No. He only checked the codes relating to the check engine light. He advised that the code was related to the O2 sensor. I replaced both of the sensors and the check engine light has not re-appeared (thus far).
My next project is the annoying aspirator fan in the overhead console. The hum is driving me crazy!
Old Jan 8, 2003 | 12:00 PM
Air Marshall Eldritch's Avatar
John Deere
How did it go changing them yourself? Was it easy?
Old Jan 8, 2003 | 01:16 PM
vwalk's Avatar
It wasn't difficult. No special tools were needed. Oxygensensors.com was a great website.
Old Jan 8, 2003 | 02:15 PM
mleskovar's Avatar
'17 Jaguar XF
O2 sensor?
Is there any kind of "life span" for an O2 sensor? I've read where people replace them proactively. Is there something in the sensors that deteriorates over time and it loses it's effectiveness?
Old Jan 8, 2003 | 02:17 PM
John Deere
I heard that they mostly get dirty and stop working. I suppose you could clean one, but I dont know how.
Old Jan 8, 2003 | 02:50 PM
vwalk's Avatar
I don't either. Let me know if you have success with it.
Old Jan 10, 2003 | 09:06 AM
mdp c230k's Avatar
2002 c230k
O2 sensors last around 60k miles on the average. If you notice a drop in mpg without any obvious problems and are over 30k on the sensor replace it. This can really help both performance and mpg.
