How to reprogram SmartKey/Keyless Go?
If they got you an additional key, it will work right away.
If they got you a replacement key,you have to put it in the ignition & there will some sort of display on the cluster telling you to wait, when that is done turn to position 2 & wait again till you are able to shift out of park.
When you are able to shift out of park its all done.
The wating time depends on how many times the old key was used for, as the programing of the new one will have to over ride all the codes from the missing key.
It could be 20 minuts & could be hours, put a batt charger on it.
The only problem is if the missing key was blocked, then he needs to go to the dealer to open the track with a green key, not das.
And you can assign more keys, but the convinience options will not work (I think).
