1999 - C230 Kompressor Sedan, POWER SEAT FAILURE
I have a 1999, C230 Kompressor with 185,000 KM's on it, everything is pretty smooth in the car and working as intended but two things.
The first, is the power seats work maybe 3 out of 8 times that I start the car - when they are not working it is not permanent ! After about 5-10 minutes of driving they will function as normal until I turn the car off for a few hours (usually 6+)
I have been searching trying to figure out what it is and the closest I got was having to replay a 'relay' in the back seat.
http://www.autohausaz.com/search/pro...ber=0015420219
Apparently that's the part I need, can somebody confirm this for me - please ! :]
The second issue which I assuming relates to this one is the power REAR headrest button does not work at all, ever.
Thanks in advance and I hope someone can help me sort this out!
-CrazyK
Also, the power headrests in my car NEVER work. Sorry I can't offer you advice, but I'm interested to hear what people say.
I did a lot of reading and that 'Relay' i posted above is the closest thing I could find to the solution - Someone said on another random forum that he bought that and replaced it, now his power seats work 100% of the time - he did not mention anything about the rear headrests.
Lets hope something comes up soon! I'll keep searching and if I get it working I'll make sure to reply or PM you
-CrazyK
I think I might have narrowed down our issue, apparently the culprit is the K24 relay module in the trunk. I was starting to suspect fuses but that would only make sense if the seats got zero power 100% of the time, anyways here is a picture of the relays in the trunk.
Swap the K24 relay with it's neighbor on the left side and see if the power seats kick in, if so.. just need to purchase a new K24 relay and replace it
Hope this helps! I will try it tonight after work and post my results.PICTURE OF TRUNK RELAY
I believe you can pick up the relay here, it's not very expensive
http://www.thepartsbin.com/catalog/?...3892&Ntt=relay
-CrazyK
The relay part # 002-542-22-19
MB dealerships sell them for $34-$44 bucks which is ridiculous, they go for about $10-$15 from online retailers. :]
Also, you can unplug the relay and try to clean it up, sometimes this fixes the issue buts its not 100%, MB says they sell a lot of these relays, apparently Siemens made a boo boo and a factory defect on them.
Anyways hope this solves tractorcrusher problem as well!
-CrazyK
I just purchased my beautiful C230 a month ago for $6,500 with 85k miles (1 owner, leased) and its my first Benz. As a kid, I used to dream of owning a Benz as my uncle played pro-football and had several. I now have one in MY garage!
To get to the point, my power seat quit working a couple days ago and I started stressing a bit. Thinking here comes the "feared MB repairs". I searched google and came across this thread and I took your advice about disconnecting the relay switch and cleaning terminals. IT WORKED PERFECTLY! So this is a huge THANK YOU to everyone who contributes to this Forum. You may not always get a "thank you" reply, but know that there are untold numbers of people who read your advice and solve their dilemmas without acknowledging it.
THANKS and lets keep it going.................
Then, I have one relay closer to the forward part of the trunk. It does not say "K24" on it. Do you know if the other relay was for different accessories my car may not have?
Also, does the car use that relay for anything else so I could try swapping it to see if it works before I pick one up?
