98 C230 Replaced Belt Tensioner Now Shaking
Old May 27, 2010 | 08:31 PM
mbc230owner's Avatar
1998 C230
My 98 C230 have original belt tensioner which is making noise now.
I got the replacement part (original part is not available anymore. got the newer replacement). After replacing the tensioner, its shaking very agressively especially when I'm in drive. Initially i thought tensioner is defective, and I ordered another tensioner but its causing the same issue.
I'm suspecting that old pulley doesn't like the newer tensioner. Can someone confirm this?? Have anyone else experienced this??
thanks
Old May 28, 2010 | 12:46 AM
nenad16's Avatar
2017 E300
sounds like the harmonic dampener was damaged during the install, have you checked it?
Old May 28, 2010 | 01:23 AM
1998 C230
If I install the original belt tensioner back, tensioner and pulley works just fine. but as soon as i replace the old tensioner to new one, the tensioner shakes excessively including pulley. Note that original part number is 11120001270 and new part that replaces has part number 1112000770. I checked many websites.. they'll have new part number selling. Dealer said the same thing that old part has been replaced by this new one. Installation was perfect... all bolts fit perfectly fine and pulley also fit in nicely.
idle position without a/c is not that bad but with AC or drive position, its pretty bad.
Old May 30, 2010 | 07:08 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The newer style tensioner requires the installation of a seperate damper (shock). If you buy from a dealer then it will list the additional parts required. You will need a damper and 2 bolts. No modifications are required to the engine to install it.
The old style tensioner had an internal damper, the new one has an external damper.
Old May 31, 2010 | 08:13 AM
vettdvr's Avatar
03 E500 and Corvette
Interesting.. Does this tensioner also fit the w211?
Old Jun 2, 2010 | 02:26 AM
1998 C230
@ausmbtech thanks.. i'll try it.
anyone have diagram/picture showing how damper fits..
Old Jun 12, 2010 | 04:28 PM
1998 C230
i bought accessory belt tensioner shock from autohausaz.. here is the link:
http://www.autohausaz.com/search/pro...98&cid=36@Belt Drive System&gid=12213@Accessory Belt Tensioner Shock
but i can fig out how this will fit... i can't find any instructions anywhere... anyone can you please advice if i'm using the right part (i didn't find any other shock part)... pictures, instructions, etc.. anything?? thanks
Old Jun 14, 2010 | 01:34 PM
1998 C230
@mbnanuet thanks for the reply... before i couldn't didn't knew the mounting points of shock... i figured that out yesterday and everything worked perfectly fine. thanks for all the help everybody.
