How Many Quarts of AT fluid for a 1999 C280?
Old May 8, 2003 | 02:06 PM
timecop369's Avatar
1999 C280 Sport
Hello,
1) Does anyone know how many quarts of AT fluid I will need in order to change for my 1999 C280? The d(st)ealers suggested 8 quarts and so that is what I bought, but she didn't seem that convinced herself.
I will be doing a complete drain, including AT filter. I have access to a friend's shop w/ hydrolic lift so it'll be much easier than if I were to do it at home.
2) Also, I heard there's two drain plugs. Can any tech savy person tell me what those are?
3) There is no AT dip stick but I heard from the dealer that their tech has a special one which you can purchase. Any idea where I can get one?
Thanks in Advance,
timecop369
Old May 8, 2003 | 08:58 PM
f4i 954's Avatar
2009 e class 2012 ml350
Trany service.
Not shore about (quarts).
It will take about 7 litres.
And yes you will need to purchase the dip stick (dealer item) to properly do the job.
If you draind the pan only it`s about 3.5 litres.
The second drain plug is on the torque converter.
When filling it back if torque converterwas drain add 3 liters, start the car & finish filing up with car running.
When your up to 6 liters stat checking the level. (to hard to remove if over field)
Old May 9, 2003 | 11:00 AM
timecop369's Avatar
1999 C280 Sport
Thanks. Another item I guess I will have to get from the dealer. Where do you insert the dipstick to check the AT fluid level?
FYI, I asked the dealer this morning and there's a special tube w/ a red dot under the hood where I can use the special dealer dipstick in to measure the AT fluid level.
Old May 9, 2003 | 07:43 PM
f4i 954's Avatar
trany
looking at the engine it will be on your left beside the last cylinder, it will have a red or black peace on top, brake it off push the remaining peace down & then pull the cap of (do not lose the o ring)
Old May 13, 2003 | 03:35 PM
RUSSH's Avatar
1995 Oldsmobile Cutlass Ciera
That's correct there is a special tool from the dealership
140-589-15-21-00 It's about $18.00 to $25.00
Be sure you're putting the special trans fluid from the dealership since you have the 722.6 trans.
Old May 13, 2003 | 03:59 PM
timecop369's Avatar
1999 C280 Sport
Thanks. It must be a Bay Area sky high prices where we still pay $2/gallon for gas and $500K for a 1600 sq. feet home because I paid $40 + tax for the special d(st)ealer dipstick!
I also got 8 liter of MB Transmission Oil at $13.50 per litre (dealer part #: 001-989-21-03-10)
I'll snap a pic tonight and post it up to see if I got the right red/black tube for measuring the AT Fluid level.
timecop369
Old May 16, 2003 | 05:12 PM
timecop369's Avatar
1999 C280 Sport
Ok, I couldn't wait till the weekend so I went ahead and changed the AT fluid, filter & pan gasket yesterday (5/15/03).
However, I couldn't find the drain plug to the torque converter. So I left that alone. But pyschologically it's killing me knowing I didn't do a complete job. Does anyone know or have a picture of the drain plug at the torque converter? My mechanic friend gave up looking for it saying the whole trans might have to be taken out to do it to get to it. That doesn't sound logical to me. I guess it'll be 15K more miles before I try and figure out this again.
FYI, if only draining from the pan & changing AT filter, it DOES only take 3.5 litre for a 1999 C280 Sport.
timecop369
Old May 16, 2003 | 10:23 PM
f4i 954's Avatar
drain
The torque converter drain it`s a 5mm alen like the pan.
To get to the drain you have to be looking at the converter & turning the crank at the same time ( turn clockwise) until you see the drain come around.
If you do this, when filing it back up put 3 liters, start the car & then add the rest.
Old May 16, 2003 | 10:25 PM
Steve Clark's Avatar
C32AMG
Did you
Roll the torque converter completely around?.I have to pry gently with a big screwdriver to slowly turn the T/C so as to expose the drain plug.
