Misfires 2003 S 600
Old Oct 14, 2012 | 09:12 AM
Nardulli's Avatar
S 600 2003
Misfires 2003 S 600
03 S600, 70,000 miles, well cared for car
Problem began with slight mis under highway speed acceleration. Backing off throttle a bit would eliminate the miss.
Gradually became more prevalent bit always under moderate to heavy acceleration. Backing off throttle solved it.
Normal driving and idle seemed perfect.
Last night attempted to pass on freeway, serious misfiring And this time was persistent. Limited to about 65 mph. Any load on engine produces misfire.
Significant loping now at idle. Check engine light now on.
I didn't suspect spark due to intermittent nature of problem, suspected fuel delivery issue. Now i am not so sure.
Mass air flow fault?
Is there an aftermarket tool that I can use to read the codes generated?
Spark plugs replaced 2,500 miles ago.
Thanks to all.
Old Oct 14, 2012 | 07:55 PM
biker349's Avatar
cl600
possible coil pack.
Old Oct 15, 2012 | 09:47 AM
Nardulli's Avatar
S 600 2003
so, next morning I drove the car, and it appears to run normally, although I did not attempt WOT acceleration.
Old Oct 15, 2012 | 10:46 AM
TMAllison's Avatar
09' E320
Why guess? Get a $50 OBDii scanner and read the code.
Old Oct 15, 2012 | 02:44 PM
Nardulli's Avatar
S 600 2003
I was under the impression that a standard scanner would not be useful with the Mercedes. Glad to know it if this is bad info.
Old Oct 15, 2012 | 05:33 PM
Nardulli's Avatar
S 600 2003
Hi All,
Codes PO 300; 303; 308; 310
Misfiring on Cylinders 3, 8 and 10.
Not much to go on... anyone have additional thoughts?
Thanks.
Jim
Old Oct 15, 2012 | 06:01 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
Swap Coil Packs from the cylinders that are OK ( 1,2,4,5,6,7,9,11,12) to the ones that are throwing codes (3,8,10) (any 3 will work)
Clear the Codes, start the car, drive it around the block, when the Codes come back, check them and see if you get them on cylinders other than (3,8,10)
If you don't get codes for 3,8,10, the coil packs are probably the issue. If the codes are the SAME as before, it might be the plugs.
Old Oct 15, 2012 | 06:20 PM
Nardulli's Avatar
S 600 2003
Thanks. Tried to erase the codes, but the low cost scanner I have just through an error. anyway... these monsters are fun, eh?
Old Oct 15, 2012 | 06:24 PM
You got it. While you're in there, it might be a good idea to have some new plugs on hand. if the car has been misfiring for a while, the plugs are probably toast as well.
Any auto parts store will read and erase your codes for you for free too. (you're going to have to get them erased right before you swap a bunch of stuff, otherwise you'll never know if it helped.)
--- also, you might get some more responses if you put this in the S600 subforum.
Old Oct 15, 2012 | 07:38 PM
Nardulli's Avatar
S 600 2003
Damn, I just replaced the plugs 2,500 miles ago. Bleh...
Old Oct 15, 2012 | 08:23 PM
benzmodz's Avatar
W203 slightly modified
I believe it may also be the dreaded head gasket syndrome.
Old Oct 15, 2012 | 09:09 PM
biker349's Avatar
cl600
if the codes stay the same after swapping coil packs it could be the throttle body.
Old Oct 17, 2012 | 10:55 AM
Nardulli's Avatar
S 600 2003
the codes show a misfire on cylinders 3, 8 and 10. So, one on left bank, two on right bank. Would be strange to have both ignition modules fail at teh same time... I erased the codes. The car seems to be running fine. But, I have not driven it extended hiway since the last episode... I am beginning to suspect a sensor. But... which one? Yikes.
Old Oct 17, 2012 | 06:03 PM
benz_addict's Avatar
V12TT
Common on these engines. Very sold engines, no head gasket issues I ever heard of.
I gaurantee it's either one of the two coil packs.
Do not listen to the swapping coil pack advice, as these cars have only 2 coil packs. They are not interchangeable.
Your problem lies either on the ignition module, or the coil pack it self (controls 1 bank, 12 plugs per side)
Not to say the least easy fix, but very expensive.
Good luck
Old Oct 18, 2012 | 06:34 AM
Nardulli's Avatar
S 600 2003
I've got misfires on both banks... So that would mean both coil packs went wrong at the same time... I've reset the codes. When it happens again, I will be able to see if it is the same cylinders.
I've found the coil packs for $990 each. Ouch.
Old Oct 18, 2012 | 11:48 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Aren't you glad you don't have 12 now???
Yeah, yeah I know.
Old Nov 12, 2012 | 06:07 PM
Nardulli's Avatar
S 600 2003
So, the saga continues. Recap: Car runs normally under mild acceleration. Smooth, etc. Can achieve speed if engine load is kept low. On hard acceleration, the car misses. If I don't back out of the throttle right away, it will throw misfire codes. Cylinders misfiring are not consistent and are on both banks of engine. Spark plugs are replaced 2,500 miles ago. Car is pristine, always well maintained. only 70K miles. Unlikely that both coils went wrong at the same time. Ideas?
Old Nov 13, 2012 | 07:50 AM
biker349's Avatar
cl600
short in throttle body, or fault in accelerator pedal. should throw a code.
Old Nov 13, 2012 | 10:10 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it is the coil packs. i have seen cars on which both go back at the same time. time to spend about 2000.
Old Nov 13, 2012 | 05:22 PM
biker349's Avatar
cl600
i had the same exact codes as you, along with a code for the accelerator pedal. the dealers tech checked the coil packs and even took out spark plugs to check. all was fine. finally figured out that there was a intermittent short in the throttle body. replaced accelerator and throttle body and all is good. the coils are a known issue, but so are the throttle body and accelerator. hope you get it sorted out without changing multiple and good parts.
Old Nov 13, 2012 | 10:24 PM
Nardulli's Avatar
S 600 2003
I assume you mean the throttle position sensor when you write "accelerator"?
I'm used to mechanical throttle bodies. Is this thing electronic? Yikes. Ever long for a carburator?
Old Nov 14, 2012 | 06:28 AM
shardul's Avatar
Yes it is an electric throttle body
Old Nov 14, 2012 | 02:33 PM
biker349's Avatar
cl600
the accelerator pedal is electronic as well. you better find a good honest mechanic, or get a mercedes repair manual or you are going to spend a fortune on replacing parts!
