2 Cars set to same key??
I asked our dealer if both cars could be set to use the same key thing (the light-emitting type) since my wife and I both drive both cars and would rather not bulk up our keychains with two keys and not have to keep track of which is which!
Seems pretty straightforward, and we can't be the only 2-MB family that have this request...
yet the dealer svc. manager says no way, can't be done. Then again, they also say you can't add Nav after the fact and we all know that's doable (thanks Steve!!)...
Anyone know if this is doable? Should be something many buyers would like...
Thanks in advance for any help,
--Josh
This is what I've learned from training materials and technical WIS info... could be wrong, though.
-s-
I'm surprised no one at MB has thought of this... it should be an option from any service center. Maybe someone there will read this and work on it for the future... they should do something like this for multi-MB owners.
Maybe our moderator can comment if he knows or has a contact at MBUSA with whom to check or to suggest this...
thanks,
--josh
...So it's the key that decides if it's in the right car, not the car that decides if the right key is in...
Keys are made for a specific car, the EZS (electronic ignition switch) too.
Before being mounted, an EZS gets programmed for a car (with a special workshop key, programmed with a key programming computer) and so are the keys (with the same key programming computer).
When you put a key in the EZS electronic codes are exchanged and various calculations are made. It is not one of both that decides if it belongs to a car but both.
For additional info, check this:
https://mbworld.org/forums/showthrea...ight=smart+key
You especcially wouldn't be able to sell one of the cars to any one you know, as most likely they would know that the keys work both cars. Too many potential problems for my taste.
That's only if they knew that key is workable with your other car which isn't real yet.
I have rolling-code garage door openers, but it's a cinch to teach it that I now have another valid opener, or to make one opener operate two doors, whatever i like. if i "sold" an opener, I can remove that opener from being listed as a valid one. no problem.
I know the cars are necessarily designed to be far more secure and it's a more complicated problem... but from a user's perspective it'd be great if it worked that simply.
Not a huge problem... just a little detail that I'd sure love to see from MB at some point.
Thanks again, this forum, as always, is incredibly helpful and I feel lucky to be part of a community with so many knowledgable people who are willing to educate, advise and share their wisdom!
--joshg
You also need to understand MB engineering. Often, they don't care what you want. Years back I went to the roll out of the W210 chassis E-Class. I asked an engineer from Sindelfingen about the lack of variable intermittent settings for the wiper. He simply stated that "Five seconds is the correct interval." His expression was "I am an engineer, and you are not...stupid."
Of course, they were working on the rain sensor system to be introduced shortly after, but again, the interval setting is not user determined, but done by the car.
The fact that Mercedes doesn't care is one thing that has made it a great marque in the past. They just made the cars they way they thought was best, and if you didn't like it, you bought something else.
