Anyone with a STAR box in the Boca Raton area?
Old Mar 14, 2013 | 05:49 PM
IBelieve's Avatar
2008 E320 Bluetec
I just replaced my conductor plate in my 2001 CLK55 and now I need the transmission code P0715 cleared.
I'm getting varied info from the local indys...
Here's some of the answers I've received:
"Just need to clear the light, you can do that with your OBDII"
and "It'll be $300.00 Cause we have to completely reprogram your transmission"
And "No one will do that without doing the transmission them selves, sorry"
So, anyone have the ability and willingness to help me in the area?
Kind of needs to be close cause I'm in "Limp Mode"
Or, is it ...off to the Dealer for me?
Old Mar 14, 2013 | 07:28 PM
Battosaii's Avatar
98 c230
you dont need a "Star Box" i replaced the conductor plate on my 98 c230 and i used my buddies tester to clear the code of course it wasnt a cheap codescanner it was a $300 scanner that does airbags trannys and abs and multiple other things so any shop will be able to clear the code there is no "reprograming" needed
Old Mar 14, 2013 | 08:00 PM
IBelieve's Avatar
2008 E320 Bluetec
Thanks Battosaii,
wonder why I can't seem to find someone with that level scanner.
I'll keep looking.
Old Mar 15, 2013 | 09:01 AM
123Pokey321's Avatar
2003 S55
I wonder if you could clear the code the same way as on a Passat; disconnect the battery and ground the cables (connect the possitive and negative cables together) for a little while. You'll probably have to reprogram a bunch of things like the radio and seats, etc but it might be something to try before going to the stealership.
BTW, I'm a former Boca resident, graduated from Boca High in '84 and FAU in '89, used to live by Spanish River Blvd and 4th Ave.
Old Mar 15, 2013 | 08:12 PM
biker349's Avatar
cl600
your taking a chance grounding the battery wires. you may mess up some electronics.
Old Mar 16, 2013 | 08:23 AM
IBelieve's Avatar
2008 E320 Bluetec
I found an Indy that said he has equipment to reset it. I'm heading out in a few minutes . He's 15 minutes away..oh, 35 minuets at 20 MPH.
Old Mar 16, 2013 | 11:07 AM
IBelieve's Avatar
2008 E320 Bluetec
Back from Germantech Automotive, LLC and Jermaine Davis reset it for me for $25.
It's running great. With the transmission Adaptive Control (ATC) reset it shifts better than ever.
Now if I could only get it to stay that way without adapting to the usual easy starts I have to do because of South East Florida traffic.
Old Mar 4, 2016 | 10:17 PM
mbw4rich's Avatar
1999 clk 320
CLK 320, E320 CONDUCTOR PLATE CODE RESET
After replacing my conductor plate in my E320, and spending money at another shop, which was not reset; I drove my car nearly from WPB and BOCA RATON TO HIS SHOP (Jermaine Davis) , He had me drive home with a smile on my face.. Thanks a lot for the reference.....
Old Mar 5, 2016 | 08:10 AM
IBelieve's Avatar
2008 E320 Bluetec
Glad he worked out. Long ride but when they work right, worrrrrrth it.
