C200k intermittently sluggish - help with understanding the fault codes
Old Apr 16, 2013 | 02:05 PM
N_trafford's Avatar
2002 C200k Estate Auto
Hi, newbie looking for advice. Have had a b service today, and codes read and cleared due to this intermittent sluggishness where car just doesn't respond as it should to throttle, no management light, no stutter, just sluggish. 10 yr old fuel filter changed but I don't think that's the culprit. have run 2 bottles of redex through in last few mths. Have looked at similar posts but this isn't identical...
P2039 m16/7 (recirculating air flap actuator) unknown fault type 8
P2036 secondary air injection: malfunction (function chain) air flow is too low [p0410]
Can anyone suggest a process of elimination I can follow to resolve?
Thanks in advance...
Old Apr 17, 2013 | 05:47 AM
N_trafford's Avatar
Can anyone help?
I've trawled and trawled and found similar but not identical probs,
Not being too technical, i havent found anything i can use to start to home in on the problem... My main questions I guess are,
Why is my management light not being triggered?
When I bought the car 4 yr ago within a wk CEL came on and I had the oily loom issue fixed, new offending leaking sensor and new wiring, luckily no ecu damage.
It looks like I may have some blocked airways? From what I've read on this forum, can anyone help me identify these to my local mechanic, is that the most likely cause?
Also the sensor down the back of the engine is mentioned, is this first port of call, if so could you give me a name and part no
We do very little mileage 13k in last 3 yrs according to MOT, which could be a cause of blockages?
I'm really to get this fixed, love the car and its lots of life left in it,
Any help would be massively appreciated
Old Apr 17, 2013 | 05:55 AM
PelicanParts.com's Avatar
SPONSOR
Answer
P2039 Recirculating air flap actuator : Adaptation Emergency running
P2036 Secondary air injection: malfunction (function chain) : Air flow is too low.
My best guess is a failed secondary air flap
whunter@pelicanparts.com
Old Apr 17, 2013 | 05:59 AM
N_trafford's Avatar
Thanks for that, is it an easy change/ pricey part?
Guess I wait for next sluggish episode, then get the part swapped, codes cleared and wait and see if it reoccurs?
Does the intermittent nature of the issue fit with your diagnosis?
Thanks again.
Old Apr 17, 2013 | 07:37 AM
SPONSOR
Answer
Thanks again.
Last I checked, it is a MB dealer part.
The unit is failing, not dead "yet".
It may be intermittent for another year, or fail today.
It fits my diagnosis very well, though I can't verify without the vehicle here.
Warning, HUMOR:
I can not think of a way for you to drive from your home to my location (Detroit, Michigan, USA).
Old Apr 17, 2013 | 08:06 AM
N_trafford's Avatar
Thanks ill look it up...
C class probably better at driving across water than it is in the snow!
Old Apr 17, 2013 | 08:25 AM
N_trafford's Avatar
damn thats expensive... is there any way to test it before shelling out?
Old Apr 25, 2013 | 08:09 PM
SPONSOR
Answer
Yes, a few thousand USD for special tools.
Old Apr 27, 2013 | 08:14 AM
N_trafford's Avatar
its like a different car since codes were reset and a b service, how can the recirculationg flap part be faulty if its working fine now, is what i dont understand?
Old Apr 29, 2013 | 11:37 AM
SPONSOR
Answer
This is a dynamic unit, with several possible failure modes, some are slow to set a fault code, others are quick to set a fault code.
If you are lucky, the codes will not come back until fall / winter.
