need a little help. sam module question.
Old May 22, 2013 | 01:29 PM
Leutrim's Avatar
Clk55
Hi, does anyone on here know if i remove my rear sam module and reinstall it if i have to reprogram it at a mercedes dealership? i took it out because it looked like it had a lot of corrosion on it and cleaned it off. didnt so much as to scratch anything inside of it and didnt use any chemicals. when i reinstalled it, the digital gas gauge will not work, the turn signals dont work, and the rear windows dont go up or down but the front ones work fine.. its a little weird but any help would be appreciated.
car is 2005 clk55 amg with command ii
Read more: https://mbworld.org/forums/audio-ele...#ixzz2U2lEQ0wA
Old May 22, 2013 | 04:03 PM
Leutrim's Avatar
Clk55
bump
Old May 22, 2013 | 04:52 PM
awiner's Avatar
2003 CL55 AMG
Shouldn't need reprogramming but sounds as if something happened to it.
Did you open it at all? Or just clean off the exterior?
Any pins bent in the connecting harness?
Old May 22, 2013 | 06:08 PM
Leutrim's Avatar
Clk55
i opened it because i wanted to see if i could see any water stains on it and there was some oxidation so i cleaned it with a paper towel. dry. and put it all back together the way it was. i called the dealer and he said i might need to reprogram because the memory chip might have erased with no power but i dont believe that, i figure its like shutting down a pc, if you save something to your hard drive and turn it off the memory is still in there.
Old May 24, 2013 | 12:54 PM
PelicanParts.com's Avatar
SPONSOR
Answer
It sounds like a circuit board Whisker (metallurgy) issue.
Here is science data on the topic.
http://en.wikipedia.org/wiki/Whisker_%28metallurgy%29
If it is the whisker issue:
When the circuit board is disturbed (attempted cleaning), then powered up, the unit is usually toasted.
The Front SAM module has been superseded Nine times.
MB# 2039060005
http://www.pelicanparts.com/cgi-bin/...I1.x=11&I1.y=8
The Rear SAM module has been superseded three times.
MB# 2095451701
http://www.pelicanparts.com/cgi-bin/...I1.x=13&I1.y=7
whunter@pelicanparts.com
Old May 24, 2013 | 01:01 PM
awiner's Avatar
2003 CL55 AMG
The memory inside the SAM is not disturbed by removing power. I would have the unit diagnosed before considering replacement but my guess is that you probably electrostatically toasted something inside it.
Old May 24, 2013 | 11:44 PM
Leutrim's Avatar
Clk55
i can see what you mean by static. but as for the circuit board Whisker issue, it didnt have anything like that. it looked brand new besides the stain i wiped off. i guess best bet is to bring to mercedes have them try to code it, if not i have to buy a new one then code that too. either way sounds expensive.
Old Jun 9, 2013 | 09:42 PM
Fattcj7's Avatar
E55
I'd go back and double check that you plugged everything back in and that the connectors are fully seated first.
Old Jun 15, 2013 | 07:12 AM
Leutrim's Avatar
Clk55
thanks to reply but i took it out like 3 or 4 times. i have to buy one on ebay and get it reporgrammed.
