Noise when slowing and turning
Old Sep 7, 2014 | 03:58 PM
JayhawkBob's Avatar
E350
I have a 2009 E 350, with 104000 miles. When I slow and turn I hear a chirping type noise, sounds like a fan, front right. I don't think it is the fan, it doesn't happen at speed, or just idling. Only when I slow, and then turn.
Any thoughts?
Old Sep 17, 2014 | 03:54 PM
Swervage's Avatar
ek4
Does it make noise when you're sitting still and turning the wheel? If so, that might be indicative of a steering pump problem but, from your description, I'd be more inclined to look at your brake pads first. Perhaps lift the front wheels off the ground and see what happens when you turn it by hand.
Old Sep 17, 2014 | 07:42 PM
JayhawkBob's Avatar
E350
Thanks, for the thoughts. I will check that out
Old Sep 18, 2014 | 12:10 PM
jaxfl's Avatar
E350
Check out this other thread.... https://mbworld.org/forums/e-class-w...el-turned.html
It might help.
Old Sep 23, 2014 | 09:02 AM
Swervage's Avatar
ek4
Possibly a ball joint is going bad, or the caliper is seized on on that wheel.
