W212 wheel speed sensor fault after wheel bearing replacement
Old Feb 1, 2021 | 11:50 PM
blacknchrome's Avatar
W212 sedan
Hey all,
I replaced both front wheel bearings and seals on my 2011 E350 RWD sedan, but when I drove it 30 yards from the shop the BRAKE warning comes on and says there's a fault and disables the traction control and ABS systems and also my cruise control won't work. I bought the MB Carsoft scanner, and sure enough both front wheel sensors were reading erratically - good for a second, then to 0, then to half of the rear wheels, then back to the same, etc. The wheel bearings and seals were National brand, supposedly the same as OEM (BCA 32008 inner, BCA A12 outer, NAT 710588 seals.)
Thinking it was the seals, I pulled the hubs and replaced both seals with OEM parts. Still get the same erratic readings on the front right but the front left reads 0 wheel speed now.
Help would be greatly appreciated before I just start throwing more money and parts at it, I'm puzzled. The seals press in flush to the hub, the ABS/wheel speed sensor appears to be fine and undamaged. I don't know what to do next except replace the sensor or maybe order the full replacement OEM hub with the bearings and races already installed since they don't sell the OEM bearings for the E212 separately but that's like $400/side!
Thanks!
Old Feb 2, 2021 | 05:46 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Did you torque the hubs properly?? When you drive is there any vibration from the wheels??
Old Feb 2, 2021 | 08:37 PM
W212 sedan
Thanks for the pointers.
There is no vibration from the wheels. I tightened the spindle nuts today and now my scanner shows steady wheel speed at both front sensors. However, I still get the fault message saying L6/1 left front axle rpm sensor has a mechanical fault and same for the right. I'm surprised since I figured now that my scanner shows it's picking up steady wheel speeds it would work! I don't have the tool to torque them to spec and can't find a good tutorial. Now that they're reading, still think that's my problem?
Old Mar 20, 2022 | 11:41 AM
ngenda's Avatar
w212 e250 cgi
Same problem
Did you managed to resolve? And are you getting the error code on both sides?
Old Mar 20, 2022 | 03:18 PM
W212 sedan
Took it to a mechanic, they ordered the whole hub and bearing kit from MB and installed. That worked. Evidently you can buy just the bearings aftermarket still (same part number and everything) but they've changed specs so that's why MB only sells the hub and bearing together. I'd recommend trying the hub/bearing combo straight from MB and see if that fixes your issues.
Old Apr 2, 2022 | 05:23 PM
w212wagin's Avatar
2014 Mercedes E350 4MATIC Wagon
Was was the bolt torque spec for the axle?
Old Apr 2, 2022 | 05:54 PM
konigstiger's Avatar
'71 Pinto
See attachment.
Old Apr 10, 2022 | 04:38 AM
ngenda's Avatar
w212 e250 cgi
Resolved
Managed to install abs ring... secret is to make sure the gap between sensor and ring is atleast 2 to 3mm... after making this adjustments the car is fine now..
Old Sep 14, 2023 | 10:30 AM
BrandanVenne's Avatar
2002 C32 AMG/1999 C230k
Just to put in my input on a similar situation, upon closer examination the tone ring/seal is not fully pressed into the hub. If you press it in fully it will be too far from the sensor causing the issues you are having. I had to use a screwdriver and a hammer and tap it back out slightly so it was closer to the wheel speed sensor. But I could not find an official specification on the distance it should be, but yes, also buying a new assembled hub will also have the correct distance set.
