2010 E250 Coupe ESL repair
Old Aug 18, 2021 | 07:40 AM
drbobub61's Avatar
2011 W204 C250 CDI
Hi all.
I have just completed the ESL repair on my E250 by replacing the Motor only after it locked up on me.
I was able to remove the ESL by drilling a 5mm hole into the side of the ESL as per a You Tube Video and manually unlock it.
I removed the 4 pins and opened it up.
Put it back into the Lock position and replaced the $10 Motor.
All worked a treat. Reassembled everything but Zip tied the ESL up under the dash.
Once Bitten.
Everything works perfect except I have a Driver Air Bag light, Park Brake Light and Traction control light on.
Any advice.
I have just disconnected my Batter for overnight.
Cheers, Rob.
Old Sep 23, 2021 | 12:14 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by drbobub61
Hi all.
Once Bitten.
Any advice.
Cheers, Rob.
Rob, did you happen to disassemble your steering column with battery connected and now you're facing multiple warning lights...?
Get an ODB2 SCANNER so you can diagnose DTC and reset modules to clear stored faults.
Old Sep 23, 2021 | 02:28 AM
drbobub61's Avatar
2011 W204 C250 CDI
I just had to get the Air Bag light cleared. $25.
The hand brake light was my fault, I dislodged the micro switch on the foot pedal.
The Traction Control light went away after disconnecting the battery overnight.
