W204 ESL motor replaced and still won't start!!!
Old Mar 5, 2022 | 12:02 PM
Polished Turd's Avatar
C300 Sport 4matic
I replaced the ESL motor in the ESL on our 2011 C300 and the car still won't start. After replacing the motor I plugged it up to test for function. The motor engages the lock when the key is removed and opens when the key is inserted. It seems to be cycling correctly but I still have the remove key message on the screen and it still won't start. Am I overlooking something here? Anyone have any ideas?
Old Mar 6, 2022 | 03:12 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
This seems like now it work like new again.
Don't mind me asking: what ODB scanner do you use to work this problem?
Old Aug 15, 2022 | 03:47 PM
beanieBenz's Avatar
'05 E500 Blk Opal/Stone, 321 AMG Package, Lighting Package, Harmon K., Parktronic, Keyless Go, Nav
There maybe a problem with the circuitry of the board. I would suggest you replace the factory ESL with an emulator. They are a lot more reliable and much less fussy than the factory ESLs. They just work.
I program emulators for $250. I would need your Ignition Switch and key to program an emulator for your car. Then it's plug n play when you get everything back. You can watch my YouTube video here:
-Michael
562.233.0989
Old Aug 16, 2022 | 04:02 PM
one way or the other
once the security is triped, you need a Xentry session to reset it
-Or the emulator solution to please EIS ignition switch again
Old Aug 25, 2022 | 11:58 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Just do an emulator. Shoot me a PM and I will give you some info.
Old Jan 25, 2024 | 05:57 AM
thegrid52's Avatar
Mercedes
Hello did you ever find a solution to this problem
Old Jan 25, 2024 | 06:07 AM
thegrid52's Avatar
Mercedes
I have the same problem
I have the same issue was it the steering lock even though it unlocks when you insert the key?
Old Feb 2, 2024 | 04:38 AM
The way car ignores key is removed says something!!
This is your ignition switch that needs to be cleaned up (optical couplers) + resolder the loose pressed pin connections.
