M272 one cam position is erratic
I have a 2011 E350 wagon with 135k miles and since I bought it 4 years ago it's made this clacking/ticking noise which comes from the (US) passenger side of the engine, at the front. From what I've read it's a pretty common issue with these engines but no one's figured out the problem or fixed it. I've never been one to leave well enough alone so I keep diving to see if I can track down the noise.
Not my car, but this is the same noise:
To recap, this noise happens once the idle drops to its lowest RPM. When you rev it just a little, the noise goes away. There aren't any known failures associated with this behavior. I've replaced the oil pump with no change and others have inspected and changed the various lifters and such in that area and found nothing remarkable.
Earlier this year I did some probing with a stethoscope and narrowed down the noise's origin to the VVT hub. I've heard of the locking pin getting stuck or its hole wearing out so I bought a Febi hub and oil control valve (2720500578) and swapped them out. Procedure went fine, but the noise persisted.
I did some testing yesterday with my Autel scanner and found a few interesting things.
- Unplugging the cam magnet and cam sensor at idle did nothing.
- I applied 12v to the magnet and confirmed it's moving freely.
- There was a fair amount of oil on the magnet's harness connector. The magnet was replaced several months ago, but the oil may(?) be left over from the prior one which was replaced about 3 years ago. I cleaned it off and will check to see if it comes back. All magnets I've used have been the updated part number (2720510177). It's had the small protection harness on it since I bought it.
- I performed the magnet actuator test via the scan tool and it worked perfectly, returning values perfectly within the range.
- I noted that this camshaft position is the only one where the magnet connector points to the side (left) instead of being vertical. Could be coincidence, but interesting.
This raises more questions than answers for me. What could be the cause of this behavior? The ECM having problems due to oil being wicked into it years ago is possible, but the problem didn't change when I unplugged both magnet and sensor, nor did it manifest on other cams when unplugging them. I know the official Mercedes line for the cause of the noise is "cylinder scoring/piston slap" but I've scoped the cylinders (and saw them from below with the oil pan off) and they looked great. It could possibly be an oil pressure problem where that hub has enough pressure to unlock the pin, but not enough to keep it from flopping around, but that's a guess.
Any advice on what to check or try next or ideas what could be the culprit would be appreciated!
I am going to go with worned out piston pin. You hear it every time that piston turns around.
Use better lubricating oil and a bit more viscosity too. I'd mix some 50 within the 40 - I know we're not supposed to but choices are few
What oil was used on this engine ??
Other thoughts for you and your 2 degrees- this side of the engine has the chain tensioner. Maybe the slack and tensioner moving at idle causes the deviation your seeing. First thought would be the intake cam would also show the deviation because of it's chain driven and the exhaust runs off a gear, but think about the exhaust adjuster and the narrow spring loaded teeth section designed to take up any gear lash. Maybe it's moving back and forth itself as the chain goes in and out of tension at a low idle speed?
I've always used Mobil 1 0w40 Euro Formula. It's occurred to me that using something a little heavier might help, but never got around to trying it for one reason or another
You're saying mix some 0w50 with 0w40? If just using another oil is the solution I'm happy with that.Other thoughts for you and your 2 degrees- this side of the engine has the chain tensioner. Maybe the slack and tensioner moving at idle causes the deviation your seeing. First thought would be the intake cam would also show the deviation because of it's chain driven and the exhaust runs off a gear, but think about the exhaust adjuster and the narrow spring loaded teeth section designed to take up any gear lash. Maybe it's moving back and forth itself as the chain goes in and out of tension at a low idle speed?
Regarding the spring-loaded teeth: I don't understand how that's supposed to work. The width of the gear is sort of sliced in two and each section is supposed to be able to move independently of each other but once the teeth are meshed with the intake hub, there should be zero situations where they would, right? The intake hub gear is solid. Unless maybe there's slop in the teeth which you would think wouldn't last long.
I means low oil pressure at idle is starving the furthest away path.
I remember reading a similar story and the owner rebuilt his oil pump thinking it was worned out.
No improvement...
I think the issue is too much leakage along the way.
How old is your chain tensioner??? On M276 it built to leak pressure when extended.
Below is my favorite old engine milk, I am usually not a fan of snake oils.
I'd use only one quart bottle of this in preferably the 10w50 or 10w40 "high mileage" type.
it has anti-friction additives that engines love beside a bit of viscosity bump.
Include that within your normal engine oil. One quart is not too strong.
Results with 1K miles or less.
Chain tensioner is new. I replaced it when I replaced the exhaust hub and valve.
Cool, I'll have to give that a try next oil change. Were you having this noise as well, or was adding a quart of that preventative?
I'm going to get my hands on an oil pressure gauge and hook it up to the testing port on the engine. It'll be interesting to see what happens!
I had access to a free 2006 260k mile m272 which had a faulty balance shaft and finally skipped and broke the chain. I took both exhaust adjusters off the motor and proceeded to take apart the LH side and inspect for damage, thinking to use the RH side on my engine, which I did, with the same results and fault codes p0014 p0015 incorrect position of the exhaust camshaft.
Some interesting things I learned so far. You CAN take these adjusters apart. I don't know what DANGER the stamped warnings refer to other than the snap ring flying off, which never happened to me. There isn't much going on inside, and my original adjuster and the 260k mile adjuster showed no obvious signs of damage. You must use a paint marker to maintain the proper position of everything. The large snap ring that tensions the thin toothed gear is difficult to reinstall. It can also be left pinned in place while removing the actuator cover. What I did notice though, is my orig. adjuster when disassembled the vanes can easily be rotated back and forth inside by hand. However, the LH 260k adjuster was "tight" and required a tool to wedge between the vanes to get them to move. Wear and debris pattern inside showed that it wasn't stuck, it was moving when on the engine.At the moment I'm working under the theory that this "loose" adjuster causes the variation of advanced/retarded camshaft timing that your scan tool sees, as well as my Xentry (DAS , really) graphs show below. The only way to prove this is to swap left and right adjusters on the same engine. I don't want to do that extra work at the moment, so I will reassemble the 260k mile "tight" LH adjuster and install on my RH bank. I will then diassemble the 260k RH adjuster and see if it's loose. I will also be looking carefully at the chain teeth on the INTAKE adjuster for excess wear.
I swapped out my adjuster for a new Febi one but absolutely nothing changed, so I can't recommend it. That said, I wouldn't blame you if you wanted to try anyway. When I disassembled the old adjuster it also looked fine, no damage or weird wear.
I have a bit of a finding myself. While I was under the hood this weekend changing oxygen sensors I got a chance to check out my ECM. I've been wondering if oil getting into it via the cam adjusters is causing it to malfunction. Sure enough, the entire engine control socket had a thin layer of oil everywhere
It's kind of tough to see in the picture, but the pins should be bright silver, not the dark color they are. I wiped some of them with a q-tip and it came out stained with motor oil.
So, I'm thinking the oil is causing the ECM to have trouble controlling and/or monitoring this exhaust cam. I think I'm going to buy a new engine harness and open up the ECM and spray it down with electronics cleaner the best I can and see where that gets me. Worst comes to worse I can always buy a new ECM but I know they're far from cheap. Mercedes recommends replacing all of the sensors and such that are connected to the engine harness since they'll all likely be contaminated too, so I'll probably do that too, and check things like the spark plug coils to see if they need to be done.
Thoughts? I'm curious to see what your ECM connectors look like too.
ME9.7 pin layout
I know they have protective pigtails for the cam adjuster magnets, but do they have any for the camshaft sensors? I've heard of (and seen, IIRC) those leaking into the wiring as well. Probably wouldn't be too hard to order the connectors and such and make some on my own. Doing the same for the crank sensor might not be a bad idea either...
I have my new engine wiring harness and I'm just waiting for a few remaining sensors to arrive. I'm hoping to get that installed in the next couple of weeks, but I know better than to expect any miracles. Opening the ECM and giving it a good cleaning and inspection feels like the next step beyond that.
Really frustrating, not sure what else the problem can be, maybe an oil pressure issue on deceleration. Even though I swapped the solenoids already, maybe I'll just try a new one. However I now suspect an oil pressure problem, my m272 has that cold start thump-thump common to these engines built before 2009. The remedy is to install tighter upper main bearing halves. Back when these cars were new MB said it wouldn't cause any problems, fast forward 15 years and 190k miles and I think differently! My engine also feels "rough" when accelerating even though I replaced the mounts. I've also got a slight crank pulley wobble that I haven't seen on 15+ other m272 I've looked at. 2 new OEM crank pulleys didn't fix the problem, I believe the crank is worn or bent. I'm not convinced a new oil pump would help either, I think the oil clearances at 190k miles is the issue. Normally I don't worry about CEL's on old cars however this one causes a 2mpg economy hit, and worse, I've had a few instances of delayed 2-3 sec throttle response when trying to pass after the CEL comes on and it's left me in some scary situations. Maybe time for a lower mileage 2010+ engine swap.... something I'm not really excited about.Last edited by E55Greasemonkey; Apr 30, 2023 at 09:09 PM.
What I have learned:
I was able to re-pin the Ebay adjuster teeth without disassembling it. It requires two people and a very large pair of snap ring pliers (18" long), along with a metal pin to hold the initial spacing before inserting the lock pin.
My original RH exhaust camshaft adjuster was bad. It became "loose" over time causing a rapid fluctuation between advance/retard as seen in my previous post. This caused two codes; p0014 and p0015. My adjuster oil control valve (bolt) felt notchy and was the first thing I replaced alone with a new OEM part.
The used 260k adjuster was too "tight" You can see the lag in the graph previously posted where it was advancing but not retarding. This caused only one code; p0015; p0014 never returned.
The used 70k miles adjuster was just right; however p0015 continued but the graph was looking much better.
Installing a new magnet eliminated the p0015 and now the graph looks good when compared to a known good ML350 with 90k miles.
Disassembling the magnet showed no failures. I found some sludge inside, but the pin still moved freely back and forth.
The final graphs below are the same test but run for different lengths of time. You can see the blue and green (LH and RH exhaust) are now synced; the red is commanded position by the ecu, there is some lag displayed between command and movement, this is normal.
