P06DA00 Code, M276 Engine, Need Clarification
Old Oct 27, 2024 | 10:27 AM
  #176
JettaRed's Avatar
Veteran: Army
I see agree, for OP's use maybe it will be fine though. That said, if they plan to keep the car for a long time, probably should get V2 and XENTRY.
Well, unless they have more than one Mercedes, I would put the money toward getting XENTRY through @BenzNinja because it will be more valuable to have a good copy of XENTRY and the diagnostic support from Peter.
I have one of each LAUNCH scanner because (1) I got the original version before V2 was released, and (2) I have two cars.
Old Oct 27, 2024 | 01:32 PM
  #177
W205C43PFL's Avatar
Looks like forum member jbanks is only interested in clearing the code and I am not sure how long they are planning to keep the vehicle. If they just want to remove the code, I wonder if they should just go to AutoZone or something and get the code erased instead of buying a scanner.
Otherwise do agree with investing in better solutions than a Launch 1.0
Old Oct 27, 2024 | 03:58 PM
  #178
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
ECU hard codes won't stay clear very long: half a sec top.
If car is up for sale... disclose modification up front.
Old Oct 27, 2024 | 04:15 PM
  #179
W205C43PFL's Avatar
They (forum member jbanks) seem to want to get rid of the code to pass inspection, probably not selling anytime soon.
Old Nov 6, 2024 | 04:13 PM
  #180
zambuzan's Avatar
FL W205 C63
M177 CEL P06DA00
Checking in to share my experience. I've read nearly every single thread and watched Tasos' videos.
My car is a 2020 w205 c63 (48k miles), has been tuned for 1k miles now, most refer to it as "stage 3" (hybrid turbos, intakes, dps, stock fuel system, custom ECU tune). About 200 miles ago, I got 1 single CEL: P06DA00. I have not unplugged any sensor. It seems that on "newer" cars like mine, the CEL will pop up. Unlike the older cars, the CEL is hidden and will not illuminate for this specific code. Indy shop diagnosed it as oil pump actuator valve wiring fault. Recommended ~$2k repair. Ouch.
The symptom is definitely there: car warms up a lot quicker. But temperature is steady, and the car has not "grenaded" despite going above 3500 RPMs. There has been no noticeable decrease in performance and the tune seems to be holding up just fine. I certainly don't think the tune is at fault.
This is my understanding: for emissions purposes, the valve functions to lower oil pressure during low engine speed (idling, cold starts, etc.). Hence a "2 stage" oil pump. If the valve is inoperative, the oil pressure is constant and not "reduced" due to engine speed.
I will follow up with my tuner to see what the best course of action will be. This is what I'm thinking: unplug the solenoid, cover the connection, and simply code out this specific CEL with a new tune file.
Old Nov 6, 2024 | 04:19 PM
  #181
W205C43PFL's Avatar
Recommend manually checking oil pressure first before unplugging and/or connecting a dummy solenoid. Just in case the solenoid is stuck closed when it failed. If that is the case yes do get the solenoid repaired. Otherwise, yes unplug the solenoid and connect a dummy externally and enjoy the benefits of normal oil pressure all the time instead of only at high rpms.
Old Nov 6, 2024 | 04:22 PM
  #182
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Close, but incomplete understanding.
With a working actuator, the ECU is able to keep the oil pressure constant until @3500RPM, and once that RPM is reached the ECU let the oil pressure climb until the maximum allowed pressure for the pump (relief valve)
With a not-working actuator (either because it is disconnected, a wiring fault or luckily stuck in the inactive position), the ECU is unable to keep the oil pressure at the desired low (but correct) pressure value, and the pump can actually increase pressure from minimum (idle) all the way to the maximum as the engine is reving up.
The important part is to find out if your oil pump is working as described above, and that can only be done with a pressure gauge and monitor the pressure gauge as you rev the engine. If the pressure is NOT going up. STOP the engine and do not run it until FIXED.
NOTE: my E350 has been unplugged for @5K+ miles already. Absolutely no issues, but an improved ride overall.
Old Nov 6, 2024 | 04:23 PM
  #183
zambuzan's Avatar
FL W205 C63
I agree, will have to manually check oil pressure. I think there is a port on the plastic oil filter. Thanks.
I don't think the solenoid has failed, given the relatively low mileage and consistent oil changes. And I would've already grenaded the engine if that was the case. Been driving with the CEL for 200+ miles now, high RPMs too. I got an oil change just yesterday, all looked good.
I did order a dummy solenoid but my tuner said he can just code out the CEL via a new tuning file.
Old Nov 6, 2024 | 04:26 PM
  #184
zambuzan's Avatar
FL W205 C63
Thanks for the comment. I will definitely manually check oil pressure. I think there is a port on the plastic oil filter. Thanks.
Like I said, been driving like this for 200+ miles, high RPMs too. Engine hasn't blown up yet. It's likely that the oil pump itself is working as it should.
Old Nov 6, 2024 | 04:36 PM
  #185
W205C43PFL's Avatar
Fully agree!
Sounds good! Forum member JettaRed shows which pressure gauge was used and how he checks the pressure: https://mbworld.org/forums/mercedes-...ml#post8961010
Old Nov 6, 2024 | 04:38 PM
  #186
THERMAL DISCONNECTION....
the epidemic of failing pump solenoid on hot engines now with CEL, make it likely there's an inline 10¢ thermal fuse that stops the dual rate operation.
Is it to prevent further heat damage or rope customers in for service?
"Oil warming up faster" in this context is a sign of better piston heat removal. This limits extreme heatsoaks. Better oil viscosity prevents it.
Old Nov 6, 2024 | 04:40 PM
  #187
W205C43PFL's Avatar
You never know
Old Nov 6, 2024 | 04:43 PM
  #188
You never know
droping oil pan on 4Matic is big bucks low skill work.
Old Nov 6, 2024 | 04:45 PM
  #189
W205C43PFL's Avatar
Thankfully forum member zambuzan have a 2020 C 63 so RWD so will be easier. That said, hopefully the manual test shows pressure is great and just a failed solenoid, if so unplug, plug a dummy solenoid and enjoy the benefits
Old Nov 6, 2024 | 05:35 PM
  #190
JettaRed's Avatar
Veteran: Army
Please see the attached procedures for manually measuring your oil pressure.
File Type: pdf
Old Nov 6, 2024 | 05:56 PM
  #191
zambuzan's Avatar
FL W205 C63
Thank you for posting this. And yikes! I hope there is enough space behind the front coolers. They sit right in front of the engine. Definitely won't be attempting this method by myself. Will reach out to my indy shop again.
Old Nov 6, 2024 | 08:40 PM
  #192
JettaRed's Avatar
Veteran: Army
A couple of your statements are not exactly correct. First, the 2-stage oil pump is primarily to reduce energy requirements to power the oil pump below certain rpm. In return, the consequence is reduced (theoretically) fuel usage. In practice, the fuel "savings" are negligible. A secondary consequence of using less fuel is to reduce emissions. Again, probably negligible. But it looks good on paper. Mercedes is not the only manufacturer to use this tactic to reduce fleet fuel consumption. If you Google "2-stage oil pump", you will find a lot about it, along with some disaster stories about the harm and damage it can do.
Secondly, the solenoid does not reduce oil pressure but limits it to approximately 2 bar below 3500 rpm and allows maximum pressure at about 4 to 4.5 bar above 3500 rpm. 3500 rpm is way above normal cruising rpm. So, when cruising, your engine is operating with limited oil pressure. With the solenoid disabled, oil pressure rises based on engine speed.
Lastly, it is unlikely that your tuner can "code out" the DTC. If they can, let us know. I have asked my tuner and other programmers, and none seem interested in trying it.
Old Nov 7, 2024 | 07:14 AM
  #193
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
A couple of your statements are not exactly correct. First, the 2-stage oil pump is primarily to reduce energy requirements to power the oil pump below certain rpm. In return, the consequence is reduced (theoretically) fuel usage. In practice, the fuel "savings" are negligible. A secondary consequence of using less fuel is to reduce emissions. Again, probably negligible...
Mercedes says 2% reduction in CO2:
This is the clearest picture I've seen which shows the location of the oil pump solenoid connector:
Old Dec 1, 2024 | 06:21 AM
  #194
MB2017Aclass200's Avatar
MB 2017 A-Class 200
Originally Posted by MMC300
Thanks for the reply. . No test just a fear. I am a total newbie here and not technical, but thankful for the knowledge!!
My car is 2017 C300 (M274) with 55,000 miles. Shop is quoting 4K USD.
I see an earlier post from CaliBenzDriver "During engine startup the ECU triggers normal pressure to help refill the hydraulic tensioners and drained VVT gears." so appears disconnecting the solenoid does just stop the oil pressure starvation. Going to try.
Other code is P012800 coolant below spec which could be what lit the CEL (although it is historical). Seems this could be ECT sensor or thermostat.
My 2017 A-class 200 (which mounts an M270 engine) is showing the exact same 2 error codes
1) P06DA00 (stored) The actuation of the valve of the oil pump in the combustion engine has an electrical fault or open circuit. There is an open circuit.
2) P012800 (Stored) The coolant temperature is below the coolant thermostat specified temperature.
Can you give us an update on whether / how you fixed yours?
Old Dec 1, 2024 | 09:24 AM
  #195
MB 2017 A-Class 200
Here is the TBS for the P012800 for the M274.
Attached here is a different TBS for the M270 and M274. If I understand correctly, it says if the vehicle was built prior to May 2017, then the ECU needs to be reprogrammed and that might fix the P012800 error code? My a Class 200 was built in 2016 - how do I reprogram the ECU?
File Type: pdf
Old Jan 28, 2025 | 06:13 PM
  #196
Johnnyb3good's Avatar
2015 W205 S205
Thank guys!
W205 C180 2015 M274
checked my car with OBD and got this fault code (Current), but with no CEL.
Dont know when this came up, because it was not there before.
Was starting to get nervous for the price and the job fixing this problem.. thankfully i found this and among other threads, that makes me sleep well tonight.
I really enjoy the car and planning to keep it.
There is no CEL and the code is current, and im not going to do anything with this.
again, THANKS to all the people for the time sharing this information.
Old Jan 28, 2025 | 06:54 PM
  #197
No-drama insurance...
Originally Posted by Johnnyb3good
W205 C180 2015 M274
You now understand that this "lucky fault" is a preview for experimental MOD-1.
This failure is a sort of natural improvement: CONGRATS!!
If you really want to sleep well tonight AND the following nights:
disconnect the harness so failed solenoid has NO WAY TO BLOW UP your engine by jamming half way with accumulated piston shavings.
It's not super-likely but you don't want to chance it either.
Old Jan 28, 2025 | 07:00 PM
  #198
JettaRed's Avatar
Veteran: Army
W205 C180 2015 M274
Hopefully if you have periodic emissions testing, the DTC won't be a problem. If it is, buy a spare solenoid off of AliExpress, disconnect the wire from the engine block, and plug in the solenoid. Zip-tie it to a coolant hose or something to keep it from dangling.
Old Jan 29, 2025 | 04:07 AM
  #199
2015 W205 S205
Trying to find out how to do this?
could you please send me a link or some pictures for this type of engine/location?
and how likely is it to happen?
Old Jan 29, 2025 | 04:13 AM
  #200
2015 W205 S205
So where i live they may sometime test emissions, but not always..
