P06DA00 Code, M276 Engine, Need Clarification
Old Jan 29, 2025 | 05:26 AM
  #201
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by Johnnyb3good
Trying to find out how to do this?
could you please send me a link or some pictures for this type of engine/location?
and how likely is it to happen?
this thread has pretty much all your answers on tap
Connector location
Old Jan 29, 2025 | 05:47 AM
  #202
Johnnyb3good's Avatar
2015 W205 S205
How likely is it to make the engine blow without taking the connector out?
Old Jan 29, 2025 | 05:48 AM
  #203
2015 W205 S205
thank you.
How likely is it to blow the engine if i DONT take the connector out?
Connector location
Old Jan 29, 2025 | 08:01 AM
  #204
JettaRed's Avatar
Veteran: Army
Depending on your engine, probably not likely IF you change your oil every 3000-5000 miles with an approved, top quality oil, and change the filter using Genuine or OE filters.
If you want to run your oil 10,000 miles between changes, your risk increases.
Old Jan 29, 2025 | 09:06 AM
  #205
2015 W205 S205
I do change oil and oem filter at 5000 miles.
But in other words, should i disconnect the connector then… or just leave it like that.
it doesnt give me CEL or jerk, the car seem to run fine.
M274 engine, 2015 modell
Old Jan 29, 2025 | 09:41 AM
  #206
W205C43PFL's Avatar
Disconnect and leave it after pressure testing confirming it is good.
Old Jan 29, 2025 | 05:32 PM
  #207
2015 W205 S205
Another code….
Got CEL, but its triggered by P0135, o2 sensor bank 1, sensor 1.
is it related to this?
Old Jan 29, 2025 | 06:42 PM
  #208
JettaRed's Avatar
Veteran: Army
It shouldn't be. I have not heard of anyone else getting that DTC.
Old Jan 29, 2025 | 08:19 PM
  #209
No, not remotely.
Upstream Lambda fault either :
the heater circuit bad or
high-mileage dirty/lazy or
CPS oil-harness contamination
Inspect and replace from a trusted part supplier.
Don't ignore this long to protect your engine.
There's a chance new sensor will fail soon as well then question thin oil consuption blow-by, cylinder bore scope...
Extreme heat is what causes solenoid nature failure... don't hang on to dirty oil because manual says you should...
Your property is under your care.
Old Jan 29, 2025 | 08:45 PM
  #210
2015 W205 S205
i changed the oil just a few days ago, and the car is only driven 97.000km
ordred new O2 sensor before the cat, going to change it when it arrives.
where is the HEATER?
And what is a CPS?
No, not remotely.
Old Jan 29, 2025 | 09:09 PM
  #211
And what is a CPS?
the lambda heater is built inside it.
It's tightly controlled by an ECU pulsed circuit.
100kKm/62kMi is an abnormal failure
-- CPS are cam sensors often responsible for oil in harmess. I mention this since yourvengine likely has a extreme heatsoaks that cook plastics. Inspect your CPS plugs for oiliness.
-- CPS can waste Lambda with oil ... see if oily when you inspect. If it is then dont replace it without replacing harness else 1 week later: it's bingo again.
Old Apr 3, 2026 | 08:30 AM
  #212
dchirica's Avatar
GLS X166 (М276) 2018
Good afternoon, very useful information here, thanks to everyone involved!
I disconnected the connector in my GLS X166 (M276), connected a dummy valve to the connector, and the error disappeared. Everything is fine.
My only question: should the valve get hot? After connecting it, the car started, and the valve became very hot.
Old Apr 3, 2026 | 09:02 AM
  #213
PotatoHeadII's Avatar
In the “off” position, the solenoid is disengaged at engine speed under 3500 rpm and no current is being applied. 3500 rpm is not the normal engine speed for most driving. Consider that highway cruising speeds are normally around or below 2000 rpm. What that means is that full current is being applied probably 99% of the time and the solenoid will get hot. Normally, the solenoid is installed in the oil pump and doesn’t care. Attaching it as a dummy reveals that it gets hot.
Have you read through the discussion in the AMG W212 forum sticky?
Old Apr 3, 2026 | 10:00 AM
  #214
dchirica's Avatar
Have you read through the discussion in the AMG W212 forum sticky?[/QUOTE]
Give me a link please
Old Apr 3, 2026 | 10:04 AM
  #215
W205C43PFL's Avatar
https://mbworld.org/forums/w212-amg/...solenoids.html
Old Apr 3, 2026 | 11:27 AM
  #216
dchirica's Avatar
I read the thread, but didn't find anything about the solenoid clone heating up, and it gets very hot.
Old Apr 3, 2026 | 11:48 AM
  #217
cutting back current
If this is the right solenoid getting too hot, feel free to experiment with getting a bit less current into a higher resistance coil or 12V automotive light bulbs.
Nobody has yet tried to defind the lower current limit of what ECU senses as an open circuit.
Chances are you can cut back the current by half for half or less of the heat output. You might be able to get by with considerably less current... 250mA based on what threshold sets a DTC.
Old Apr 3, 2026 | 01:50 PM
  #218
W205C43PFL's Avatar
Sorry about that, read it wrong.
Old Apr 3, 2026 | 02:29 PM
  #219
dchirica's Avatar
I will study it again)
Old Apr 3, 2026 | 02:30 PM
  #220
W205C43PFL's Avatar
Sorry about that I mean I read your question wrong
Old Apr 4, 2026 | 04:41 PM
  #221
I messed up my statement and actually said things backwards. Under 3500 rpm, the solenoid is activated and normally restricts oil pressure. There is current being applied full time until 3500 rpm is reached and the solenoid is deactivated. At idle, I imaging the solenoid would get hot.
Old Apr 4, 2026 | 05:12 PM
  #222
+1: All true statements.
  • solenoid ON: lowers pump output volume
  • solenoid OFF: Normal pump volume (pressure)
Stock setup runs the pistons with limited cooling under 3500R to save gas from less oil friction.
MOD-1:5W-40 allows effective spray that unfortunately is still above normal driving range.
Accumulated HEAT is always a factor without effective piston spraying. Pistons need to be more than just wet.
Old Apr 5, 2026 | 08:58 PM
  #223
AlexMonroe75's Avatar
i ran into a similar issue on my 2022 S 63 with the same code and engine. it turned out to be a faulty MAF sensor, but in your case, have you checked the fuel pressure sensor also?
Old Apr 11, 2026 | 05:09 PM
  #224
overanalyze's Avatar
2015 GL450
I just wanted to log on and say a huge thank you for all the info in this thread!! My 2015 GL450 has 230k miles. I just had the passenger side intake phaser and camshaft replaced along with a few other parts MB recommended while it was apart. The P06DA00 code was current. I want to verify my oil pressure before I disconnect the sensor. Where is the test port so I can check? I have the M276 TT engine.
Old Apr 11, 2026 | 05:38 PM
  #225
Your oil pump harness having failed: P06DA00
there is no real need to disconnect pump solenoid to stop the limited oil pressure mode.
The harness open circuit is "disconnected" inside the oil pan ($10k service job).
Your engine enabled "normal oiling" all by itself: MOD-1 as a mean of protection against extreme heat. Stay on top of all coolant leaks.
There is an oil pressure port located on the engine front below than oil filter, very close to serpentine belt. Its a flat round screw.
Some ppl buy a new oil filter cover and use the old cap to screw in a test pressure port on top of old filter cap. No issue messing with belt then.
Favorable options are to service clean oil on 5kMi. schedule and upgrade to "MB Approved" PAO oil such as MOTUL 5W-40 or better.
