BAS/ESP/etc. shut off again! mbtech please help
Here they are:
ECU, ESP, Part#2095450232, C1145, Zero point offset error of component Pressure sensor
ECU, EIS, Part#2035450508, B1004, Overvoltage supply
ECU, OCP, Part#2038201201, B1002, The supply voltage of the control unit is too high (overvoltage).
ECU, UCP, Part#2038217458, B1036, Control module N72/1 (Upper control panel control module) has detected undervoltage or overvoltage.
Battery voltage 11.71V
This phraze I don't understand
"Zero point offset error of component Pressure sensor"
All other ECU's mentioned will not cause BAS/ESP-warnings.
"The outside may change, but the soul remains the same."
The fault code 1145 (pressure sensor) is caused by a bad ESP-unit. From may 2002 on, all ESP-ECU's have extra condensators (is this proper English?). Replacing the pressure sensor will not help.
I think it's called condenser, but I'm not 100% positive.
So in your opinion what needs to be replaced, ESP unit? ECU? both?
We will see...
