US to Europe Light Conversion (Red To Amber)
Old Apr 25, 2024 | 08:30 AM
Vole2's Avatar
Gls
I bought a US GLS 450 (X166) from the US to Europe but unfortunately, it has red turn signals and in Europe, amber must be used.
I have bought some aftermarket lights and added them, they still flash red, and apparently, an additional cable needs to be run to the SAM module.
1) has anyone done this before?
3) where can I get a wiring diagram of the rear electrics?
4) Estimate time for this job? 1 guy wants to charge me for 3 days of labour. I find that hard to believe when it is "only" running a cable from the lights to the rear SAM unit from each light.
Old Apr 25, 2024 | 02:17 PM
JettaRed's Avatar
Veteran: Army
What are the aftermarket lights that you got? Do they claim to be amber or red? Can you provide a link?
I would contact @BenzNinja at www.benzninja.com to see if changing the color can be done through software configuration.
Old Apr 25, 2024 | 04:44 PM
Vole2's Avatar
Gls
@JettaRed here are the links to the aftermarket lights. I bought them in Poland. I guess some Chinese brand.
https://autolampylach.pl/lampy-tylne...rawa-nowa.html
Getting the originals changed to amber is also possible I think. I will contact Ninja also.
Old Apr 25, 2024 | 08:31 PM
JettaRed's Avatar
Veteran: Army
Since the lights say they are European Version, I would think they should be amber. But, because they are red when installed in a US car, it makes me think that there needs to be a configuration change in the control module.
By the way, DEPO is a well known aftermarket manufacturer. The quality is generally good.
Old Apr 26, 2024 | 06:26 AM
ygmn's Avatar
2015 E400 Sedan
Look red to me?
Old Apr 26, 2024 | 07:24 AM
JettaRed's Avatar
Veteran: Army
Originally Posted by ygmn
Look red to me?
He needs the turn signal to flash amber.
Interestingly, this US spec GLS450 appears to have amber tail lights, but I suspect it's just how the photo captures the color.
Old May 2, 2024 | 11:25 AM
Vole2's Avatar
Gls
@BenzNinja says it is too much hassle, so I am back to square 1. Anyone know where I can get the wiring diagram?
Old May 2, 2024 | 09:37 PM
JettaRed's Avatar
Veteran: Army
How did you bring the car over to Europe from the US? Have you contacted a Mercedes dealership in Europe?
Old May 3, 2024 | 02:20 AM
Vole2's Avatar
Gls
They are telling me they have to replace the SAM module and lights. They " do not do modifications". No thanks when I know only a wire is needed
Old Jun 6, 2024 | 10:00 AM
Rickman30's Avatar
Veteran: Navy
2014 Mercedes-Benz E350
I remember seeing a YouTube video doing this exact mod, but on a W212 E-class. Should be similar, or at least give you enough info to know what and where to look. Use OE wire diagram to find exact output for the Amber turn signal that will require an extra wire to be run for it
Old Sep 13, 2024 | 04:48 PM
Resko's Avatar
2018 Amg GT, 2018 Tesla S P100D, 2016 Ford Mega Raptor
Hello, has this been solved yet, and can you share a solution, i am looking for the same answer.
Old Oct 23, 2024 | 05:00 AM
Heywood_ja's Avatar
Same issue- I am told need
EU lights
Wire to the amber pin in light from SAM
Reprogram.
I am In Germany, and MB corporate will not allow dearers to do this swap (Although they did the headlight swap/reprogram)
Did you solve this?
