Gremlin of the day- intermittent lamp malfunction, but it works fine, W209
Old Nov 17, 2024 | 12:30 PM
Sixcarbs's Avatar
2003 CLK 320 Cabriolet (W209)
So I have been getting an intermittent malfunction- "License plate lamp, right" but when I get out of the car and look at it it is lit up just fine, same as the left.
Should I change the bulb anyway, or is that a waste of time? Any thoughts on what it could be?
Thank you,
Sixcarbs
Old Nov 19, 2024 | 02:43 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Working bulbs... faulted by SAM !
That is a strange combination you got!
Is this harness flexing during trunk opening by any chance??
The Rear-SAM module poor connections may be acting up.
Can you reproduce fault using your scanner test functions?
Old Nov 19, 2024 | 02:48 PM
Sixcarbs's Avatar
The Rear-SAM module may be suffering from its poor connections.
I rarely open the trunk. I will need to see if I can find the harness. The whole Rear SAM was recently redone. I don't have a scanner.
I was going to take the bulb out and clean the ends and connections.
It's just strange because it pops up, I get out and check and the light is perfectly illuminated. And then sometimes it does not show any malfunctions.
Thank you, I will poke around there tomorrow in the light of day.
Old Nov 19, 2024 | 02:52 PM
prior related repair....
Why was your "Rear-SAM redone" ?
SAM replaced with a different unit... used/new?
This current issue is likely the aftermath of that earlier battle.
Let's understand what happened BEFORE to plan what to do AFTER...
Don't tinker with the bulbs just now or shop will say YOU messed them up... for an extra $500 billing
Old Nov 19, 2024 | 02:57 PM
Sixcarbs's Avatar
Not really sure of the details. All I know is it seemed like all of my problems went away after they repaired the front and rear SAM, plus some other wires I talked about it here:
https://mbworld.org/forums/mercedes-...-320-w209.html
I guess I should pay them a visit again.
Old Nov 19, 2024 | 03:04 PM
that is directly a YES to that
Let them finish their fine surgery job.
This can be caused by a "simple" programming issue and take north of 4 hours to locate the correct config file...
Old Nov 30, 2024 | 05:57 AM
Sixcarbs's Avatar
Well, I have been too busy to get back to that electronics place. The intermittent malfunction error continued along with the lamp working just fine. Until a few days ago when I then noticed the light was out.
It turns out the computer is smarter than we thought and was trying to warn me about a sick light, soon to die. I changed it this morning. The old one below is clearly toast.
Burned out bulb up top, new one from Mercedes dealer in plastic below.
