Possible Active Steering Assist Issue?
I have a question/concern about Active Steering Assist on my W465 G63.
I live in Canada and make long journeys, so I appreciate Active Distance Assist DISTRONIC and Active Steering Assist. The Active Distance cruise control works great, but I’ve noticed the Steering Assist doesn’t.
When the system is on I notice that the vehicle gently but noticeably “bounces” between the lane markings. It drives in a zig zag pattern, not aggressively, but it’s noticeable and really annoying! It never drives in a straight line. I keep my hands/hand firmly on the wheel without tugging to one side or the other, I make sure all the sensors are clean and unobstructed, but it still does this.
My RS6 keeps the car straight as an arrow, the Tesla Plaid I used to have was straight as an arrow.
Has anyone else, in any newer model Merc or AMG with Active Distance Assist DISTRONIC and Active Steering Assist noticed this as well? Has anyone with a 2025 G noticed this?
I’m hoping this is a calibration issue because if it isn’t, IMO the steering assist is useless. Pretty sure it makes me look drunk to other drivers.
P.S. Please spare me the “just drive the vehicle yourself”, “I’d never let a computer be in charge of my safety”, “Shoulda got a 1979 Ford pickup with a 7.5 liter V8, seats made out of rusty knives and snake fangs, guns that shoot you if you even attempt to use the AC on a 120 degree day, and a speedometer that punches you in the face if you drive under 60MPH through a school zone like a real man!” comments.
90% chance it's your MFK stereoscopic camera working poorly.
-A- You should get it worked on by a MB specialist
-B- You could scan your chassis for active network issues
-C- You could rework that specific solderless module and clean its merki optics.
I can attest the DistroPlus with active lane works with much finer resolution using normal electronics:
- Forward cameras trajectory MFK!!
- Steering module angle sensor SCM!!
- (Higher resolution wheel braking ESP)
> Misc:
(Forward 3x radars + harness)
Distronic controller: ok!
Throttle control ECU: ok!
(I forgot what gateway this network is using?)
Fixing No1 and 2 is guaranteed to put a smile on your face or a hole in your pocket.
Let me get you a few pics of MFK here...
dirty/foggy dual caneras optics...
solderless pins always impact networking
The windshield glass also gets dirty on the inner side. You can clean that without any electronics skills. Don't scratch plastic lens while at it.
This whole navigation system can disfunction quietly without any direct error as in your case but you can really tell it's consistently working poorly between lanes markings.
Well worth half an hour of time.
The windshield cameras and rain sensor are tuned to the windshield glass type. Replacement windshields require calibration.
Your stereo camera has a harder time to delineate contrast lines.
Edit: I hope you’re right cause I love it and it was expensive. All the searches I’ve done say the film is so thin and the optical clarity so good that it doesn’t affect ADAS or cameras. If I get it removed and it still does it, I’m going to HUNT YOU DOWN and say to your FACE: Thanks for the recommendation, it was worth a try! Have a great day
I am sure a windshield protector is the way to go. These windshield glass chip like there's no tomorrow.
without any fancy MFK or Distronic.
The electric rack speed sensitive function is virtually disabled by the solderless SCM.
I am sure many haven't noticed this function missing!
When it's working you can easily drive with one hand at any speed. The car stays put and tracks straight courtesy of steering column and steering rack working well together.
This is really comfortable on highway. The opposite is unstable chassis moved around easily.
Solderless quietly wasting performance from the first day.
If not I’ll take it to a bunch of dealers hoping one will say “that isn’t normal” because I’m pretty sure most of them will say it is normal.
I can already hear it… “It’s a driving aid, not self driving”
A driving aid that replicates drunk driving, sounds good!
because of chassis alignment issue
where I am saying it's an MFK optical issue.
Read the specifics.... if the alignment is poor enough to cause instability then it should keep to one side without wandering and if it doesn't Distronic won't be top concern.
- so not the control arms
- not the faulty rack
- not tie rods
- but System performance.
There's no guarantee OP doesn't drive off curbs or potholes... Story does not hint to that now we know windshield's undercover.
experiment cutting film slots before pealing off film.
Look into the cameras to see if windshield + lens are foggy. They do get dirty even in clean driving environment.
Get this working well... you'll enjoy this every day in traffic stop and go or hwy cruising. It normally operates smoothly.
Clean sprayed durt from he back of the front radar plastic cover to increase radar sensitivity back to normal.
When you activate Distronic with Steering Assyst, the system keeps as No1 priority the driver wish, so if driver wants to bounce, the car will bounce. Also if the vehicle alignment is wrong or the tires is old the system ( steering Assyst) will not differentiate the driver steering over the car steering and it will try to put the car in the middle of the lane, as the alignment will put the car outside the lane and so on.
Also, if Camera or radars is misaligned or foggy, ,the Germans engineers already wrote a lot of lines with code about even Fault Codes.
Obviously if the car doesn't drive straight "Lane Assist" is not going to make miracles.
The issue here is pinned on optical combined with poor highspeed networking.
W465 is a very new model and has one of the most advanced electronics
I’d never let a computer be in charge of my safety.
BUT, there is some legitimacy to looking for physical/mechanical problems. The vehicle is too new to need tires already (I'm guessing). However, if they have been changed, I would look closely at that. You may even try rotating them front to rear if they are all the same. I had a problem with my 2000 Ford F150 pulling right no matter what alignment was done. Then one day I decided to swap tires around and the problem disappeared. If this drifting problem has been there from the begining, maybe it's the tires.
When you had the screen protector put on the windshield, was the camera recailbrated?
If you turn off the Active Steering Assist and Active Distance Assist DISTRONIC, does the G-mobil wander?
I need that Ford! The G drives PERFECTLY fine. Tires are brand new just like the truck, they are winters but it’s the winter wheel and tire package from Mercedes. Drives true and steers straight in all situations, including on the highway, when I hold the steering wheel straight I don’t have to adjust it at all during straight line travel. Turns and maneuvers without any problems. Lane Keep Assist works as intended with zero issues.
It’s perfect, except the Active Steering Assist with Distronic activated slowly makes the G drive in a zig zag pattern down the highway, even if I hold the steering wheel as tight as possible it still does it. During gentle curves and turns on the highway it doesn’t do this, only straight highway sections, which makes it all the more odd. Nothing too dangerous or jarring, but very annoying, to the point I don’t use the Active Steer anymore just the Distronic.
It’s not like the G is bouncing off the painted lane lines, it doesn’t get close enough too them for the Lane Keep to kick in, it just doesn’t drive in a straight line. After 10 or so kilometres it even makes you feel nauseous from gently weaving constantly.
There is windshield protection installed, the manufacturers website says it’s thin enough and has such high optical quality that ADAS’s aren’t affected. Plus wouldn’t this also make the Lane Keep Assist, rain sensing wipers, traffic sign recognition and Distronic vehicle speed adjustment based on visual input from speed limit signs also not work as intended?
I did disable the Active Lane Assist where the car jerks back into the lane if you approach the side markers. Now I get just the steering wheel vibration like rumble strips.
