We need and M276 engine forum
Besides a lot of open issues are developed to be re-used across the board on other engine/chassis/makes.
We're dealing with low voltage, extreme heat, limited oiling, leaky connectors, rusted lines, unstable modules, CAN delays, .... & advanced rubber formulation!
Well spec'ed to be manageable.
Site engagement is all that matters.
Engagement is harmed by efficient user experience.
Engagement is helped by a site with a flea market of unorganized information that users need to spend much time pawing through it all to find one somewhat useful fragment.
Contribute what you find works best.
You may organize your topics:
repair / maintenance / troubleshooting / specifics...
Every contributor comes in with his own perspectives. Free help is often welcome.
what sensor / mounted where
what gauge / mounted where
The M276-NA Bosch ECU has no oil sensor, can you live without one?
We know where to sense oil PRESSURE of the cooled oil near filter.
Engine oil temp is not the same every where.
Which one are you interested in?
What oil temp is best : hotter oil or cooler oil?
Minimal operating temperature for oil is 176°F (80°C). Below that, you are cautioned to drive gently. My normal temps for both my cars in the summer are 196°F to 215°F, with mostly 198°F to 205°F.
We know the oil temperature for the M276 (and others) is calculated and not measured. A while back, I measured my oil temp at the oil drain plug using an IR thermometer (actually two and took the average). The measured temps were within 1°F of the displayed (calculated) temperature. My cars (2015 SL400 and 2014 C350) will display the oil temp if you have the AMG menu added by @BenzNinja . So, whatever algorithm is used by Bosch to determine the oil temp based on a bunch of datapoints (ambient temp, transmission temp, coolant temp, load, RPMs, etc.), it seems to work.
The other I was scouting around my cluster menus and managed to enable the oil menu.
I didn't get any data so I removed the option.
blank oil data
My ECU knows nothing about engine oil that can be displayed, not even computed number from misc inputs.
