Gas pump cuts off prematurely and multiple times when filling up, B200 (W246)
Old Mar 8, 2026 | 09:25 AM
Sixcarbs's Avatar
2003 CLK 320 Cabriolet (W209)
My wife's 2013 B 200, W246.
Whenever I take it to the gas station to get gas, it cuts off after a gallon or two no matter how empty the tank is, especially if I run the gas pump at full speed. If I do run it at full speed it will often spill fuel over the side of the car as it cuts off.
In order to put gas in. the car I have to fill it at a super slow rate, and even that still cuts off towards the end before the tank is full.
Your thoughts please?
Thank you,
Sixcarbs
(I am in Eastern Europe. We do not have nice seals that go around the pipe like in the US.)
Old Mar 8, 2026 | 10:41 AM
chassis's Avatar
2017 GLE350 4MATIC
Petrol correct? Replace the purge valve and canister.
Old Mar 8, 2026 | 12:00 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
there you go...
The tank vapor canister can get damaged when tank gets overfilled way up
Then tank is unable to vent in or out... ie. burp pressure out.
Canister is located in one of the rear wheel well behind plastic covers.
Old Mar 8, 2026 | 01:12 PM
Sixcarbs's Avatar
Thank you @CaliBenzDriver and @chassis!
Is this a DIY type of job or best left to a shop?
(It is an ordinary gasoline engine.)
Old Mar 8, 2026 | 02:43 PM
I think it's an easy job to messup with dirt contamination and get fault code CEL from it.
Pull out vapor canister to empty fuel from it or replace it new if recognized as bad. It maybe a twisted pipe or something unforseen too... meaning this is not a scheduled failure. It's unusual repair.
Old Mar 9, 2026 | 09:11 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
@Sixcarbs
Vapor cannister. Clean the filter under the valve.
https://mbworld.org/forums/w211-amg/...0-01-59-a.html
https://mbworld.org/forums/e-class-w...e-testing.html
