Sunroof switch
Ted
At least you can close it with the remote once you get out, but that doesn't help much while accelerating onto the freeway and trying to get it closed!
I agree with the other posts: this is a silly feature, whether or not their argument is based upon safety. I have a friend who's a Denali fiend, his factory sunroof has auto open and close, and the aftermarket sunroof he installed in his other Denali also has auto open and close. As well as 5 memory positions so he can select certain favorite positions.
...........Begining in late 2001, "auto open" feature was introduced in MB vehicles. So any post 2001 ML should have this feature.
Ted
Ted
You are correct, blood is much harder to clean off of the headliner.
...........if you hold your remote key within 12 inches of the remote eye located next to the driver's side door handle, and if you subsequently depress the door closure button on your remote key and hold it, it will close your windows and your sunroof.
Ted
Also, NO W163 ML's have the open/close feature for the windows and sunroof using the key from outside of the car.
Even the C230 kompressor has automatic close/open/tilt for the sunroof and the close/open feature using the smartkey outside of the car, which makes me wonder why it wasn't available for the W163
I dont have this.. unless im doing it wrong someway..
