ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Need help dropping my ml55 2000
Old Feb 25, 2009 | 03:00 AM
revolutionml55's Avatar
Porsche993-ML55AMG-WRX STI-soon e55 211
Anyone know wich suspension i could use to drop my truck??
William
Old Feb 25, 2009 | 04:05 PM
amg8451's Avatar
What do you mean by "suspension"? To drop the rear you will need to invest in Springs from either H&R or Eibach. Since you are going to replace the rear springs it might be a good time to also replace the rear shocks. for the rear shocks you might want to look into Bilstein (ride will get pretty harsh). For the fronts you can just adjust the torsion bar nut to lower the fronts. The shocks in the front can be replaced at anytime, but you might get a better deal when you order the front and rear shocks at the same time. Let me know if you need help. I have lowered both my 2001 and 2002 ML55 (2002 was just done recently).
Old Feb 25, 2009 | 09:05 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
How would this porcess differ from getting a Brbaus lowering module that involves no mechanical changes?? i am not a mechanic and a novice just want to learn. Can anyone help? i want to lower my ML63
Old Feb 26, 2009 | 12:01 PM
amg8451's Avatar
Lowering a 63 would be a whole different process. On the ML63 is the suspension airmatic?? If it is then you can purchase some adjustable links from (Adjustable Air Ride) and replace the links (I think). I just lowered a 2007 S550 and this was the method that we used, so if Mercedes did the the same suspension setup on the ML63, which I think that they would because the Airmatic suspension on a 2006 E500 was almost the same as the S550 (where the links where located) then it should be pretty simple. We lowered the S550 in about an hour.
Old Feb 27, 2009 | 10:11 PM
Thanks for the info do you have the part numbers for the bilstein and the H&Rs?
Your car looks sweet with the drop in your signature ..do you have a bigger pic?
Will
Old Feb 27, 2009 | 11:13 PM
azizblue's Avatar
2011 s63 amg
i need to lower mine to
Old Mar 6, 2009 | 11:52 AM
amg8451's Avatar
sorry it took so long to respond, I've been pretty busy. Here are some pics of when I was selling the 2001. https://mbworld.org/forums/m-class-w...ml55-sale.html . for the springs there are two different types 1) Flat top 2) round top. You need to make sure that you get the right one. The best way to check is to jack the rear end up and check the top of the springs. It will be a little hard since it is being pressed against the spring pads. But if you run your fingers along the top of springs to where the spring ends, you can tell if they are round or flat by the way it sits against the spring pad. For the part numbers I do not remember you're going to just have to google it. I can give you pointers on install if you need help though.
Old Jul 31, 2009 | 05:26 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
do you need a spring compressor for the rear?
Old Aug 4, 2009 | 06:27 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
yep
