ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2015 ML63 what’s this thing in the engine?
Old Aug 31, 2019 | 02:29 PM
LeadfootZ3's Avatar
ml63amg
New to the ML world. Lifted the engine center plastic cover and saw this little tank. What is it? Is it supposed to be empty?
Old Sep 1, 2019 | 07:29 PM
chassis's Avatar
2017 GLE350 4MATIC
https://www.mercedesbenzstarparts.co...bC12OC1nYXM%3D
It's a coolant recovery tank. I have kept them full on my various vehicles. I'm not sure how MB uses the to manage coolant level. Bone dry would raise questions to me.
Old Sep 1, 2019 | 07:50 PM
LeadfootZ3's Avatar
ml63amg
So two expansion tanks?
This one is at the right level. Should I add coolant to the other one below the engine cover?
This would be the first car I own with two expansion tanks. The one above is what I’m familiar with.
Old Sep 1, 2019 | 08:10 PM
whoover's Avatar
'19 E63S sedan
It's the tank for the intercooler coolant, which is a separate circuit from the engine cooler. If it's dry you should probably have it checked. Have you done any wide-open runs to see if you're suffering from heat soak?
Old Sep 1, 2019 | 08:28 PM
LeadfootZ3's Avatar
ml63amg
I haven’t really push it but for a few seconds at a time. It runs great.
Thanks for your reply. I’ll go look again, it may not be dry, I hardly looked at it.
Old Sep 2, 2019 | 12:28 AM
whoover's Avatar
'19 E63S sedan
Keep in mind that this system should never get very hot (intake air temperature should be kept to ambient + 20 degrees) so it's not an expansion tank. Unless there's a leak you wouldn't expect the level to drop much. It would be good to see how high your IAT goes under heavy load.
Old Sep 2, 2019 | 08:10 AM
LeadfootZ3's Avatar
ml63amg
IAT? How to measure?
Old Sep 2, 2019 | 09:47 AM
whoover's Avatar
'19 E63S sedan
Intake air temperature. An ODB scanner that you can get for around $100 will display it in real time. Or, if the tank is empty, let a shop diagnose it.
Old Sep 2, 2019 | 10:05 AM
LeadfootZ3's Avatar
ml63amg
Got it. Thanks. You’ve been very helpful!
