ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Ml55 fuel pump fault
Old Dec 15, 2019 | 12:47 PM
Chris england's Avatar
ML55
Hi all, I have a 2001 ML55 AMG and it was running fine then when i parked for an hour it started then when i put it in reverse it died and cranked but would not start. I have checked the voltage at the fuel pump in the tank and have 12V even when the ignition is off?? I also have a humming from the back of the engine when the ignition is on, Fuel pump has not made any noise.
Started the next day then after 5 secs it stuttered and died then back to cranking only.
Any help would be much appreciated.
Many thanks.
Chris.
Old Dec 15, 2019 | 03:59 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the ML.
What condition is the vehicle battery? Low battery often produces strange behavior. It's one item to rule out.
Try also positing the question in the section of the site specific to your vehicle, it will receive more visibility from a fellow owner.
Old Dec 16, 2019 | 03:55 AM
ML55
Hi, Many thanks for your info. the battery is new and still not sure why i have 12V at pump even when fuse is pulled?? It is wet in the foot well and i know i have to remove the driver side wing and pull the sunroof pipe back through the inner wing.
Cheers
Old Dec 16, 2019 | 09:36 AM
dbldpr's Avatar
Veteran: Navy
Welcome hope you figure out what is wrong. someone here might be able to help.
Old Dec 16, 2019 | 10:45 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W163 AMG forum...
Old Feb 18, 2020 | 10:35 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Better late than never (doing a search myself for reading material....)
perhaps this issue - https://mbworld.org/forums/ml55-amg-...fuel-pump.html
