$1475 for a 2nd FOB - Australia Tax
Unfortunately for me, it only had one key. The car is the pushbutton Keyless-Go and after some research, it seems to be a dealer only purchase.
They quoted me $1475 for the replacement, including programming, with a 1 week turn around.
Are there no other ways to get a 2nd fob, that does not equate to a monopolistic *** reaming from the dealer ?
Might be worth a call?
https://www.mbstuttgart.com.au/en/desktop/home.html
Or search Ebay for brand new "mercedes keyless go key", you will find new ones for under $200 out of the States or Canada, but it has to be new, you can not use a used key as its locked to the car it came from, the new key will need to be programmed by a locksmith as the dealer wont touch it, so finding a locksmith that has the right gear to do Merc keys in your area will be the next task, but they are around.
See if you can get the part number from the dealer to make sure you are getting the right key, as there are a few different keys and frequencies they run on.
i will try the place you suggested.
hopefully someone else chimes in from Sydney with a suggestion.
the dealer i called said the key alone was $1226, the rest is programming.
i tried calling an automotive locksmith, but he said they did not do my car as it is the same cost as a dealer.
hopefully I can get a get done cheaper.
Call two Mercedes dealers in each of the largest cities in Australia and see what range of prices you find.
The most annoying thing, is I have to take the car to the dealer and provide proof of ownership and be registered in their system. They will then order the key, which takes 5 business days. I then need to bring the car back to the dealer and have the key programmed to the car. 2 Trips to the dealer is crazy, as I do not really have any local ones.
I wonder if the ACCC would do anything about Mercedes monopolistic pricing.....
Have you found any Non dealer service centres that can point you in the right direction, most of these guys know where to get stuff that we dont?
I have a mate that services just Mercedes ( not dealer ), he usually has all the contacts for 99.9% of parts, he is on holiday until the 6th, ill ask him when he is back, He had sourced me some platinum gold unobtanium priced parts before at 1/4 of the price in the past, and seems to have a answer for every Mercedes problem I have come across
