Thinking about a 13' ML63
Sorry not sure how the PPI process works in the United States, in my country this would definitely be the responsibility of the buyer to organize and pay for prior to signing a purchase contract.
The brake, transfer case and differential fluids are not expensive to replace and neither are the CPS's.
If you do end up going ahead with the purchase you'd want to consider replacing the CPS's as preventative maintenance. This is a good write up of what could occur if these (and possibly the cam magnets) are not monitored for internal oil leakage:
https://mbworld.org/forums/w212-amg/...ispreloading=1
I noticed this ML63 has red painted brake calipers, I haven't seen this before on a non-PP vehicle, have to assume they were painted or upgraded after it left the factory:
VIN 4JGDA7EB8DA119461
B06 BRAKE CALIPERS PAINTED SILVER
Something else, there are a number of exterior trim panels at the front and rear which were chrome/silver colored from the factory, but are now painted black - just an observation, looks good to me!
As for the PPI, the tech when i called them, said they did a multi line inspection on the car but I'm not sure if that's the same or even consists of the same points an actual PPI would cover.
I would assume those fluid changes are pretty standard like other cars/trucks when changing them? Just use the correct fluids and should be pretty simple or in other words, a local shop could do this VS the dealer? Now when you say the CPS's aren't expensive to replace, you're talking about the Cam Position Sensors right? Don't those require the front of the motor to be removed? The check valves would also be done at the same time correct? I was quoted like $3,200 for that job on my ML350 a few years ago.
Yeah I noticed on the build order the calipers were silver but they are now red. I was guessing either the previous owner may have painted them OR he ordered them red without the PP package? It has a standard plastic engine cover so I know it's not the PP and it also has the wood steering wheel (which I'm not a fan of and would like to switch it for the flat bottom one). And yes it seems that all the chrome has been deleted from this one...one less thing for me to do lol.
Yes, a local shop can change the fluids, it's a simple job.
Yes CPS's (Cam Position Sensors) are little sensors that sit on top of the valve covers - if you can change a light bulb you'll have no problems doing this yourself, plenty of videos online, this is a good one:
I also noticed the non-flat bottomed steering wheel, looks like it was optioned from the factory:
289 LEATHER STEERING WHEEL WITH TRIM INSERT
- front bumper was popping out at the passenger side headlight.
- running light was loose
- passenger wheel well cover was missing, exposing headlight wires.
- hood vents were broke and glued in lol
- oil residue was visible on passenger side wastegate. Maybe something was leaking at some point?
- almost all wood pieces inside were cracked
- center console and dash was worn pretty good. All the A/C vents werent working either (directional parts)
- very loud rattle when hitting bumps coming from pano area. Sounded like a loose bolt or something?
- volume knob for radio didn't work
- buttons on steering wheel were bubbling
- all the chrome pieces that were painted black were starting to bubble
- calipers were painted red but AMG logos were installed backwards 😂
With all that, im going to pass and keep looking. Also I wanted to say THANK YOU to everyone who commented and helped me here. You all are awesome.
I can supply the VIN for this one too if needed? Im thinking about going to look at this one today.
Love the exterior improvements of the GLE over the ML, especially the front end, but do not like the newer dashboard and steering wheel. Also prefer the factory ML63 wheels.
