Fuel pump relay keeps blowing
Old Feb 17, 2020 | 02:46 AM
jasontarwater85's Avatar
2001 Mercedes clk55 amg
Hey guys 2001 clk55 amg here has been sitting for years I tow it home put a fuel pump on it, and a filter,, fires right up,, I drive it for a few days and it does,, I concluded it was the relay,, I replaced it and it fired up again, but 15 mins later died again,, what would cause it to keep blowing relays? Thanks in advance
Old Feb 17, 2020 | 05:53 AM
optimusprime m1's Avatar
W124 260E
Check all the wires you fitted to the fuel pumps .You might have them in reverse . Also earth points on the fuel pum to body. This might be missing .Also my first check would be to find the right part number for your relay and see if yours is the same . If wrong relay is fitted it will work for a short time .Also the same applies to your fuel pump .Overloading of the fuel pump relay due to the wrong fuel pumps . Please let us know how you get on with this .
Old Feb 17, 2020 | 09:04 AM
dbldpr's Avatar
Veteran: Navy
Welcome could be a bad fuel filter or sludge in the gas tank that is clogging the lines. If there was sludge in fuel lines it would travel to the new filter and clog it. you should have drain the gas tank also before you started it up.
Old Feb 17, 2020 | 10:13 AM
W124 260E
Filter can cause this ,,.and the wrong pump ,,or relay . Just because the parts look the same, the numbers must match the part you removed .Or get numbers for the items that shoiuld be fitted and compare them with those in your car. Most owners not knowing any better just look at the part and in their minds eye view right away think its the one . . So what numbers do you have on your relay,, and pump ,,so we can check to see it those are the right parts for your car .
Old Feb 17, 2020 | 03:17 PM
the oe pump numbers are, 7.21960.04
the new pump I have is e8929
the oe relay is
And the new relay is
Old Feb 17, 2020 | 08:45 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the CLK.
Old Feb 18, 2020 | 10:43 AM
W124 260E
Can anyone look up these numbers of the fuel pump and also the relay .To make sure they are for the said vehicle . Help !
Old Feb 18, 2020 | 08:42 PM
chassis's Avatar
2017 GLE350 4MATIC
A0025421319 appears to be a valid part number for your vehicle.
A2024702641 sensor with pump, appears to be the fuel pump for your vehicle
The pump part number you provided is not valid. All of the preceding info is from EPC.
Old Feb 19, 2020 | 04:15 AM
W124 260E
Thanks for your help Cassis .. Now its up to Jason to check those numbers you gave him .
