Sat nav
I'm new to MB world
I hope someone can help I have a 2015 250 C class my comand has been playing up for a couple of weeks it freezes when I first turn the car on and now the Sat nav won't load when I press the nav button it just says reading data and then goes off. I've attached a pic
Hope someone can help
I do have a USB plugged in but that is the message that comes up when I press the nav button and the nav function doesn't work. I will try to use the w204 forum
Thanks Marc
Try to go to NAV and cannot read Hard drive and crashes and locks up and I have to reboot (hold power button thingy down)
Been haing this problem for ever....
Now I have 2015 E400 but Command is about the same as yours...
No cure I know of other then trying this:
Pull all COMMAND fuses to HARD RESET system.
Worked for me once...
Call XM and tell them to turn off Free XM - That worked for me in the middle of one of my trips after driving for 4 hours without nav.
Try dealership while it is doing this to see if they can fix as my guess when XM comes on some software bug messes up NAV and well MB has not figured it out yet after all these years as it never happens when you bring car into dealer
Good Luck!
Thanks for the reply. Not sure what the XM is but I will try the power button first. If that doesn't work I'll pull the fuses. I think there in the fuse box under the bonnet block number 11 according to the chart. Hopefully that will work if not a call to the warranty company and off to the dealers. Just something I could do with out before Xmas
Cheers Marc
Cheers Marc
if you are in another country then my guess is the fiber optic loop connecting components found one that is behaving badly so it just locks up the head unit as a fix...
Which is not a fix but an annoyance!
Mine just ends up fixing it self after a few days or weeks. Crazy thing Wish dealer would take it serious they tried upgrading command software no luck
you need to take it to dealer when this is happening as it is a software BLUE SCREEN of DEATH type thing.
I can have USB music in or out still happens. am or fm radio, CD in or even go to settings and she will lock up.
Locks up quickest in NAV though.
