LS1 in 300SEL?? Anyone done it?
I know the purist argument of putting a GM motor in a Benz but the 350 motor is one of the strongest motors ever developed. And if you gotta stay pure you have to throw away Cobras, Panteras, Masarati's, Cunninghams, Nobles, Lotus, etc.
Anyone done, know who does it?
The 300 has 3.46 rear end to make up for 177HP on starts, the 420 and 560 have 2.47 which makes the motor a bit quieter on the road. The lower diff on the 300 negates any fuel savings you would expect. I have been told not to try and put a 560 diff in for fuel savings as it would be very slow out of the hole.
My thought is to put a large lightweight motor (LS1 is lighter than any of the Benz motors of the era) with either 6sp ZF manual or auto tranny from Vette which is very smooth and use the rear diff from a 560 which will hold the power. That would give me options to map a LS1 ECU which is available in a million variations, potential for very cheap turbo or supercharging and replacement parts, if necessary anywhere. I have had LS1's in my trucks for company use and heavy towing (work and race cars) and have never had a failure in 600K miles. Initial expections are 400bhp and 30+mpg in initial tuning with a 6sp which will have the car cruising at 1800rpm at 80 or so.
Good part about the setup with <6lb of boost is that I don't need to rebuild the bottom of the motor with lower compression.
