Question about Evosport Underdrive Pulley
........Is there still a benefit from the Evosport underdrive pulley if your airconditioner is turned off when you are in the staging lane at the dragstrip?
Ted
Ted
Originally Posted by Vadim @ MBLN
Evosport UD pulleys do not underdrive A/C. Only Power Steering, Water Pump and Alternator.
Ted
S600TT, R350
No, we have over seveeral hundered kits out in the field and no problems. Water pumps have a very wide rpm range where their efficiency is high enough to keep engine cooling in check.
SLK 230K
Since the motor have to spend LESS energy to move the OTHER parts.... MORE HP are AVAILABLE to MOVE THE CAR! heheheheheheh
is just an OPTIMIZATION of the LOSSES!!!!!!
2001,CL 500
i am about to install my pulley..has there ever been reports of cars breaking down or parts becoming stressed due to the new pulley..i am about to drive cross country and don't want the pulley to jeapordizer it or leave me stranded..of course i would like it installed before i go..so i hope it works good...anyone know
MBworld Guru
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Originally Posted by OCKlasse
My brother has EVOsport pullies on his C43, and on his way back from Arizona (to California) the pulley belt snapped on the 55 and he was left stranded.
2001,CL 500
My brother has EVOsport pullies on his C43, and on his way back from Arizona (to California) the pulley belt snapped on the 55 and he was left stranded. Not meaning to deface EVO at all, just want to let you know that he did have an issue, and this happened approximately 8,000 miles after the purchase of the pulley. Another belt was purchased from EVO and there have not been any issues since.
2001,CL 500
by the way i have a cl500///so i have a different sort of pulley kit...this is going to frighten me now..what if i get stuck in iowa in the middle of the night helpless...because i drive hard too...i am not going to be *****footing once its on....so evosport make me feel at ease here, i spent 400 dollars proably for a few horsepower.
2001,CL 500
when i ordered it i did verify i said listen dont get me out on the road and these things just snap or break..of course i was assured they are ok they have to move product out the door..anyway i think the cl500 kit is very simple so i am hoping they wont strand me somewhere as that is my biggest automotive fear....im wondering if the evosport guy can jump back in here and just say something.
MBworld Guru
Originally Posted by C43AMG
Aside from the obvious , how does your brother like the pully upgrade?
MBworld Guru
Originally Posted by SDR
Any belt can snap. Just make sure the kit is installed properly and everything is aligned as it should be.
2003 CL500
hello, mr. baldwin. this is not related to your topic but i am in need of some
guidance. a LONG time ago you had offered contact information on a person in the atlanta area who can make comand units play DVDs, even if the headunit is a 2003 model. can you let me know?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Ted
totally unacceptable in my mind. my evosport pulley caused similar problems with belt shredding and such. The Renntech pulley that I later installed caused zero problems after many thousands of miles. The Renntech pulley is a modified stocker and that is why it worked much better than the new pulley that Evosport tried to produce. I had the first generation pulley from evosport but the newer ones may have fixed the earlier issues.
If the pullies are shredding belts, etc, then possibly the pullies are not aligned properly. Possibly the power steering pulley was not pressed on far enough and its causing the belt not to track straight. Check the workmanship of the mechanic before you blame the workmanship of the pullies! I have had my pullies on now for almost 65k and havent had one problem with belts or anything!
XLR
OK I have A QUESTION:
Will a Underdrive evoport pulley kit with belt from a 00' ML 320 fit on an 01' ML 55 ???
I was told YES by Dale a general questions guy at Evosport and NO by some other sales guy at the same company. This was all over the phone, Dale assured me that they would fit that its bascially the same engine. what are your guys thought. Thanks!
Stage 2 C7 A6, QX60
55 is kompressor engine, and is also hand made
Most likely he was referring to the configuration of the water pump, alternator, power steering pump and belt size in relation to both motors. Just because one car has a 8 cylinders doesn't mean that the rest of the components are specific to that car. Car companies try to design cars so that their parts can be used across several models in order to keep design and production costs lower.
I don't remember in relation to the belt, but I know the pulleys themselves can work on both models.
