Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
TUNING CHIPS ....combine all info here
Old Jan 20, 2002 | 04:17 PM
Bux's Avatar
Bux
G
everyone is asking about TUNING CHIPS! oberklasse, UPSOLUTE, Wetterauer, and this company http://www.hs-elektronik.com/datenbl...s-c32-amg.html
everyone has a little piece of info on whats what for which car etc.
there is alot of confusion so lets make this one nice big tuning chip thread.
i want a chip under $500 that adds around 30hp + removes top speed limiter even though i hit 160 the other day. i run 13.2's at the track with stock tires. and im just dreading to hit the high 12's so i can say i have a 12 sec car
Old Jan 20, 2002 | 06:09 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Talking GOT BOOST?
I would TRY the UPSOLUTE PROGRAM...I GAINED 30 HP at the rear wheels on a DYNO (EVO SPORTS DYNO )and its UNDER your 500.00 limit so what more could you ask for ?well........
as the CCoupe is a LOT faster NOW JUST MY .02
Old Jan 20, 2002 | 06:13 PM
Bux's Avatar
Bux
G
badass
but the reason i don't think UPSOLUTE has something for my car is because i met up with the UPSOLUTE distributor last night! and raced around with him an dhe never mentioned anything about a chip for my car (C32)....and there closed today..but what you have done is badass thats exactly what i want...did they reprogram what you have? or added stuff? and can you reset it back to factory defaults?
Old Jan 20, 2002 | 06:22 PM
Thumbs up UPSOLUTE
I would Talk to Lanny,in CHINO HILLS, CAL cause upsolute did not have a program for my c coupe BUT THEY MADE ONE FOR ME .FIRST THEY REMOVE THE M E CONTROL UNIT...Then read it and save the file ....Then remap and reinstall and WA LA ........
MORE POWER and yes you can reprogram to stock if needed
Why? cause there is no way to tell anyone has been a playn with the M E control unit
I can tell you this cause Im a ex factory mb tech .......... UPSOLUTE WORKS
Old Jan 21, 2002 | 03:16 PM
Sleestack's Avatar
Just to let you know, Oberklasse is not a chip tuning manufacturer. They are a full aftermarket tuner in Texas that uses MKB parts. They did reprogram my ECU as part of my tuning program, however, I don't think they offer straight chip tuning.
Old Jan 21, 2002 | 03:29 PM
STKLAW's Avatar
2010 E550
Great idea for a thread. Let's hear the CHIP CHAT roar!
Old Jan 22, 2002 | 01:44 AM
Sleestack's Avatar
Check out www.mkb-power.de. I had their 55 Hypertune kit installed by Oberklasse and they reprogrammed my ECU.
Old Oct 17, 2002 | 04:27 PM
jcjmw's Avatar
2005 E55 Wagon
Anybody with an E55 that has the Upsolute Chip?
Old Oct 17, 2002 | 07:32 PM
geoff_r's Avatar
slk 230
A little clarification about Oberklasse. They don't reprogram your ECU, they have it reset so it can recognize or learn your new parts quicker.
Old Oct 18, 2002 | 01:55 PM
Sleestack's Avatar
They do ECU reprogramming using MKB software (unless something has changed in the last year), however it is not a part of the 55 Hypertune kit. The ECU reset is something that everyone does ( and is easily done) after installing new parts.
Old Oct 18, 2002 | 02:04 PM
jcjmw's Avatar
2005 E55 Wagon
Sleestack
What kind of times are you running with the Hypertune Kit?
Old Oct 18, 2002 | 03:18 PM
Sleestack's Avatar
Not sure... I was running 490 hp and 460 lb/ft torque with the Hypertune kit and a Kleemann SC (and a4.3 liter engine)but that was before the current round of upgrades. I also had a higher differential. After this round my car will definitely be put thorugh the ringer so I'll post all performance numbers when testing is done.
Old Oct 18, 2002 | 04:41 PM
JAYCL600's Avatar
new balance
Sleestak
Nice car Sleestak, I was curious as to wether or not you ever rear wheel dynoed your vehicle, or have you ever taken it to a drag strip to see what kind of times you would post?
Old Oct 21, 2002 | 03:24 PM
Sleestack's Avatar
Re: Sleestak
The numbers I am giving are derived from dyno runs on both a Dynojet and a Dynapak dyno. Haven't been to the drag strip yet.
Old Oct 21, 2002 | 04:56 PM
Air Marshall Eldritch's Avatar
John Deere
I still want to know if the rumor is true, whereby the Upsolute chip increase is soon erased by the car "relearning" something or other.
Old Oct 21, 2002 | 05:04 PM
If You Have any Questions RE The UPSOLUTE software please contact UPSOLUTE @WWW.UPSOLUTE.com
I Can Say That after Several programs done by Upsolute
That The M.E. control unit has NOT lost the Program Update!
Just Runs a Lot Stronger! (Its Over a Year on the Upgrade)
Old Oct 21, 2002 | 06:56 PM
JAYCL600's Avatar
new balance
SLEESTAK
So, what you have posted are your hypothetical flywheel numbers relative to your corrected SAE rear wheel #'s?
Old Oct 21, 2002 | 07:14 PM
Sleestack's Avatar
Re: SLEESTAK
Yeah, with a generous power loss factor for the automatic transmission. The SAE corrected rear wheel numbers were 395 hp and 370 lb/ft torque to the rear wheel.... that, however, was after round 2... round 3 is coming.
Old Oct 25, 2002 | 03:10 PM
Post
Sleestack, Round Three (CKRET Project) Looks Like you are Most serious! Will there Be A Round Four? BTW Yes I have Seen Your CLK!
Also Did You apply for your Pilots License?
Old Oct 28, 2002 | 01:04 PM
Sleestack's Avatar
No round four... round three should result in a *****-out CLK that makes women and children run for cover... say hi to my CLK if you see it again.
