Boost Kit for New 1.8
2003 C230K Magma, C7, 6 spd.
Do you have an idea of what Renntech is doing, changing just one pulley or 4 and by how much? My guess is that they will make a larger crank pulley like on the 2.3L using the factory pulley with a ring but then give you a larger waterpump, power steering, a/c, alt pullies to correct the speed on those or some of those. This should be a pricy kit, don't count on it being only $1,600 from Renntech like for the 2.3L, it may likely be about $2,000 like the C32 kit with 3 pulleys.
If you know what you want, send ASP the corresponding factory pulley and they'll make you one in any diameter you want or if it's the crank pulley they can fabricate a ring for it so that you don't lose the factory damper. They already make pulley kits for the C230K 2.3L (coupe and sedans) , SLK230 (all years), SL55, E55, SLK32 and C32.
Do you have an idea of what Renntech is doing, changing just one pulley or 4 and by how much? My guess is that they will make a larger crank pulley like on the 2.3L using the factory pulley with a ring but then give you a smaller waterpump, power steering, a/c, alt pullies to correct the speed on those or some of those. This should be a pricy kit, don't count on it being only $1,600 from Renntech like for the 2.3L, it may likely be about $2,000 like the C32 kit with 3 pulleys.
Cant you tell me more about this ASP thing and how i can get ahold of them. Mabey I'm just missing something but I not sure what everybody is talking about when they refer to ASP.
The only thing renntech said was that they do the same thing as AMG but im not sure, what that is cause i didnt know AMG had a boost kit availible.
Auto Specialties Performance
13313 Redfish, #104
Stafford, TX 77477
(281) 261-5811
(281) 261-5715 Fax
E-mail: asp@aspracing.com
http://www.aspracing.com/frame.htm
You will need to talk to Lee.
Why won't ASP add MB to their web site?
NP
2003 C230K magma, C5, C7, 6 spd
You still in Lancaster? I am down in York and just noticed another fellow MB owner near me. You are the first this close that is on the forum that I have seen. We should get together sometime and see what we can do to bring these 2003's up to 2002 pulleyed performance levels. Why should the 2002 owners get to have all the fun.
Hey whats up, Thats cool your near by. I work at the dealer in lancaster so if you you stop over I can hook you up if you need any warrenty work or mods. I got one mod right now i developed this week thats working pretty good already. Today I installed clear corner lenses and they're pretty sweet. As soon as I get a chance im gona go to the drag strip and see what I can get done with it. I'll be over to the circut with my friends next time its good weather too mabey I'll see you there.
2003 C230k magma, c5 , c7, 6 spd
