Upgrading rear differential from 2.65 to 2.82
This is my first post in this forume. So I wish not making any miss.
I recently bought an 2004 S500 V8 RWD from a friend and it has broked rear differential. I bought a used one with higher ratio, mine were 2.65 and the new was 2.82. I was looking for better performance with higher ration so I go for it and was smiling but this didn't last long after I put the pumpkin into my Mercedes. The diff is put right into the place and once U took it for drive test. the surprise that I never exppect is that the transmission is not shifting and is due to diff change. Is what I did right, is it ok to change gear ratio or it is not possible and I have to put same number which is 2.65.
Thank you every body
NAbeel
you will either have to go back to stock ratio or have the tcm reprogrammed for the correct ratio.
i'm doing a similar mod on my car to 3.06, i have a different year and different trans so mine is a little different. But if you contact most of the performance tuners they can program it for you if you ship it to them.
if you can give me website, or any contact for a shop who can do this for me i will be so thankful.
It is better to bear the cost of shipping and reprogramming than seeing the Mercedes parked forever.
and what about transmission, is it capable of handling the new rato?
Thank you so much.
if that doesnt work i can let you know places in the US
Yes the trans will be fine. Different models come with different ratio's and the same transmission.
I contacted Kleemann but it didn't work out as they are very very expensive. Could give me other names in the US. Euro area are very expensive as usual.
Many Thanks
Kleemann is good and they know wht they are doing, but they are costy. Do you have other names?
Many thanks
I believe Renntech is now in Stuart, Florida.
Regards,
Jerry
