How to disable ESP for dyno?
That was the case when I was drag racing.... but now that I think about it.... I guess the difference is that the front wheels aren't rotating on a dyno
so I guess it still makes sense
The best way to turn it off is to pull the relay, or disconnect the pump at the source.
KLEEMANN may be able to give you the details on the latter.
John.
If you want to totally turn it off do a search on this forum. I think someone listed on how to totally turn it off but i'm not sure if it applies to your model???
That tip was only for the C-Class (W203) models.
I think that was mbtech208 that should us how to disable the ESP but only for the C32, i believe. As for turn off ESP at dyno, that is what ****'s at Dynospotracing told. Even though the ESP light is still flashing but he said that it does not effect your dyno result. Dynospotracing have dyno machine themself too. If you check their's wed site at www.dynospotracing.com, you will see the Slk 230 on their's dyno machines.
JamE55,
.....it brought up a menu that was completely in German.....and nothing resembled the word "dyno"as is displayed on the C class.
