Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
Adding picture to signature?
Old May 17, 2004 | 11:46 PM
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
How do I add a banner or picture to my signature, Like some people? Any help would be greatly appreciated.
Old May 18, 2004 | 03:11 AM
theitalianjob's Avatar
E46 M3
If you don't have a server, you can upload it here:
http://www.stlhosting.com/upload/
It will give you a link and copy it, go to > edit options > signature, put [img] codes with your link there, then click submit modifications.
Hope that helps.
Old May 18, 2004 | 03:21 AM
Rareamg's Avatar
Thank you!!
Old May 18, 2004 | 03:35 AM
Rareamg's Avatar
ok where do I put the IMG code???? Sorry... Can you show me a sample??? Pleazze...
Old May 18, 2004 | 11:56 AM
revstriker's Avatar
K Car
Actually, it's "User CP" and then "Edit Profile". If you scroll down, you will see a box for signature. You can enter the address of your picture with the [/IMG] ending and the [IMG] at the beginning.
Old May 18, 2004 | 12:48 PM
Rareamg's Avatar
thank you it works!!!!!
Old May 29, 2004 | 09:42 PM
imthduke's Avatar
E55
What am I doing wrong....it wont work for me?
Old May 30, 2004 | 04:05 PM
revstriker's Avatar
K Car
You need to have a place to host your picture. Then all you need to do, is follow the directions I posted above.
If you're still having a problem, post the address of your picture (http://....) so we can see if there is a problem with linking to that site.
Old May 30, 2004 | 04:48 PM
imthduke's Avatar
E55
http://www.treasureislandbedandbreak.../sparetire.htm
Old Jun 1, 2004 | 12:52 PM
victor20170's Avatar
06 325i
You are posting the link to the webpage where the pictures is located. You should be using this instead
http://www.treasureislandbedandbreak.../sparetire.jpg
Old Jun 1, 2004 | 03:54 PM
revstriker's Avatar
K Car
victor20170's got it right. In order to post a picture using the IMG tags, you need to have the address of the picture, not just the site where it's hosted (usually will end with .jpg, or .gif)
If you go to a site that has a picture you want to link to, right click on the picture and select "properties". You will then see the properties window which list the URL address of the picture. You can copy the address from here (Ctrl+C), and then paste it into your message, or signature (Ctrl+V), between the IMG tags.
