7G transmission
One of which is annoying 3-2 rough downshifting (not 2-1 since it is present in both C and S drive modes) which my SA called "normal" behavior for 7G transmission. However, this known issue with solution.
Ask your SA to look into
TSB Number: T-27-60-68
Good luck
#1: Faulty temp sensor caused the radiator fan to run randomly. Oh boy, does R500 has loud radiator fan when it is running full speed. Inside indoor parking structure, I could hear her driving by as it sounded like airplane landing. It was fixed by our dealer and problem solved.
#2: Rough downshifting from 3rd to 2nd gear when coming to complete stop or rolling stop. This is common in 7G transmission but R500 jerking was excessive. Fixed with valve body replacement (see my other post with service bulletin #)
#3: Left front brake grinding noise. This is mistery so far. It happens randomly on and off. Of course never when we take it in to dealer. Sounds like "metal on metal" grinding which is loud enough to turn other driver's head. Problem not fixed yet.
#4: Passenger side windshield wiper flew off by itself! Faulty connection assembly. Fixed with wiper assembly replacement.
#5: Static noise in built-in Aux port.
Despite of these problems (I question Alabama assembly's QA control), we love our R500. For our need of hauling people around, there isn't any better option in my mind. Surprising for its size and length, R class drives "small" and feels nimble enough.
Must options are: parktronic and airmatic.
Mine shifts rough in "comfort" mode, it seems fine in "sport" mode.
Dealer told me the tranny must be driven up to 5000 miles before adapting to my driving style. This sound like a bunch of baloney. If it is true, I am not looking forward to the next 5000 miles. Does this mean that if I keep the car for 3 years that for 6 months or 1/6 of the time of ownership the thing can drive like crap?
As far as I can tell all the 7 speed tranny's are suspect.
Would like to hear some feed back from others with similar problems.
I sat in a Q7 and was not impressed with the interior room or lay out. I'm a huge Audi fan yet was unimpressed.
I hope that everything works out for you. Good luck.
More to follow...
Steve
More to follow...
Steve
